If I am not wrong there is no statistical evidence to prove that dampened improves anything. I am sure Dippy will confirm that too. One might suggest that the engine feels smoother at idle but that's about all we know. MRC have been using solid lightweight oversize crank pulleys for years without any problems. The performance gains are negligible if any or maybe not. I'd rather spend this money on rear ARB, CR-15 strut brace, transmission and street density mounts to make the car feel smoother overall.
@RyanJonS4 - I have the 189mm Vdamper kit - I asked MRC what size their standard "high torque" pulley is so that I could order the same size. I thought that this would be the safest since I have the CREC engine, and we know from APR's testing that the supercharger clutch can slip under high load. I know that MRC have tested the CREC engine with a 189mm pulley but I don't think they have tried a bigger one yet.
Based on my dyno results there is no difference in performance with damped vs solid. I do think the idle is smoother but only slightly. Indeed its all about being prepared to pay extra in order to mitigate an unknown risk. But that was an easy decision for me: I had my B5 S4 for 13 years because it was such a great car. Perhaps I should have changed it sooner because I love my S5 even more. It is quite likely that I will keep it for a long time, so having the peace of mind that my crank pulley is damped is worth the money I spent.
Let us know how that goes, won't you, @Dippy?FIS Control MMI is due to launch in April. Fortunately my S5 is now old enough for me to be less sensitive about pulling the trim apart than I was when I fitted the dashcam. I'm hoping I won't have to pull the MMI apart in order to get to the connectors, but I suspect I will.
I don't think there should be any issue about the timing of the fault. As you say, the Stage 2 might be an issue but hard to see why.Warranty claim?
I recently posted either here or on A5OC about the capacity of the windscreen wash, because I seemed to have had to fill up the container more often. Well now after leaving my car at Heathrow T5 car park for 10 days I now have proof that there is a leak. The car is in for a service at MDM Technik tomorrow and Mark will check what he suspects - the leak is from one or both headlight jets - he has replaced many. I have an MOT booked at Audi Basingstoke on Friday and have asked for a diagnosis. The warranty runs out on Saturday.
I have never had to make a car warranty claim so I shall stay open-minded. Will having the fault diagnosed the day before the warranty expires allow my claim to be valid? I should think so but maybe the dealer will disagree. Then there's the matter of my stage 2. Watch this space...
P.S. I have decided to have my used gearbox oil analysed. Partly because of this cost, but mainly because I don't think it is worth doing, I won't be getting the engine oil analysed this time.
This seems to be one of the "known" faults that I didn't know about. I bet the dealers don't know about it either - like they don't know about s-tronic gearbox faults!I had my driver side replaced and sadly it happened two months after the warranty expired.
Indeed - I'll write up the install. However there is still no news about availability...Let us know how that goes, won't you, @Dippy?
My warranty runs out on 30 June this year. Methinks I'll check my washers.This seems to be one of the "known" faults that I didn't know about. I bet the dealers don't know about it either - like they don't know about s-tronic gearbox faults!
That would have hacked me off. I think I'd prefer them to deny knowledge of a fault rather than admit that it's a known fault and say "tough - your warranty expired"!I believe they know and so does Audi. When I booked in mine the Service Manager said, 'it is very common with jet washers and we replace them a lot". And to which I replied it should be free to replace if it is a known fault and that so many get replaced every week. I did get it replaced at dealership prices though - for us the 'commoners' the replacement cost is in the region of £350 - £375 (don't remember the exact cost but I can check) and I paid £220-ish as I had to chase Oxford Audi 9 times for 4 weeks before they ordered the parts. Talk about customer service.
MDM Technik did not give me a quote, but advised me that the cost of the part is about £50...
Thanks - in that case I'll be expecting zero cost for mine...They didn't charge me for diagnostics but only parts and labour.
The cost of my service - engine oil/filter and gearbox oil/filter and pre-MOT inspection - was £474.41.
Mark said he took the oil sample both from the start of the drain and the end in order to mix in any sediment. However the oil looks pretty clear to me (although since the car has only done 12706 miles I guess it should). I'll post the results of the analysis next week.
At less than 13K have I got the record for the earliest gearbox service?
