Speed Camera Detection
If you're simply after being alerted (visual only) of cameras (including SPECS and red light) then see here
http://www.audi-sport.net/xf/threads/speed-camera-poi.248853/
If you want more than that, then yes you'll have to look into a device like the one you posted. They're a good brand but that's all I know, never used any of their products first hand
Thanks mate that's a help!
Works great and for a much cheaper price
ALSO... I just realised you'll have a FL rather than PFL... Someone on the thread mentioned an audible tone being possible with some tweak / messing around... although I'm not sure if that was for non-UK cars or FL cars only... worth looking into! It's in that thread somewhere I'm sure in the last couple of pages
Will certainly check it out!
Will give anything a try if it works lol!
Reactions: azibux1
Just don't speed
Reactions: AudiNutta and samo26
I'm sure I've popped the audible tone alert on to sisters A3 - there's an option within the MMI for this...will need to check next time I see her
Reactions: samo26 and azibux1
Dropped a text to sister to check and she gets the pop up and beep tone to alert her of cameras
Reactions: azibux1
Oh that's great will look into it!
Guessing I will need to pay to have the sat nav activated first.
Reactions: DeanoC
New to these systems but does this detect scatter from mobile guns etc?
How well does that work in the armrest? I have been put off by detectors as I don't like cables around the dash but if this works well in the armrest then I'd be very tempted
The unit works off a GPS database, updates are available daily and cover most of the counties you can think of. Has three different warning volume levels so the armrest can be closed / down. Has no issues with keeping a GPS signal also however it can take 5 mins to establish said signal.
This is not a detector.
When I was researching around the internet most people said that if you have a "detecting unit", by the time it alerts you you have already been caught.
Reactions: Flying Scotsman, Audi Bairn and samo26
Interesting @DJAlix. Seen those on Amazon with good reviews.
Do you just leave it plugged in to a USB charger I guess and it auto powers and shuts down?
For the money its not bad at all. It has a battery in it but I just leave it plugged in to one of my USB sockets in the armrest. The car power shuts down a few mins after locking (FL), then once the internal battery runs out the unit dies but starts straight up again without issue when the doors are next unlocked. It only leaves my armrest when I remember / want to do a database update.
Reactions: azibux1
Nice! Might check one out from amazon since they have a friendly returns policy
Accurate and free database updates, directional notifications, configurable distance alerts and even trip recording if you want. For £35 you can't go wrong. Once thing I forgot to mention tho is that the memory is a little on the small side. You can have all of the UK and a couple of other countries loaded without issue but not the whole of europe at the same time.
Thanks for the mini-review
Sounds great to be honest for £35... Like I say saw it previously but I think what put me off was someone saying it needs to be on / near the windscreen
I think (haven't looked yet again) it does all sorts of cameras also? SPECS etc?
Memory thing won't be an issue for me, UK alone is fine
Also can you turn off things like accident blackspots and mobile zones? They could get annoying
Strangely quite a few bad reviews on amazon, more 1 star than there are 5 star
Any chance you could have a read and see if you've had any of those issues please?
If you use your phone in your car, TomTom do a free app that I've been satisfied with so far...
https://play.google.com/store/apps/details?id=com.tomtom.speedcams.android.map
I don't know if there's an Apple/iOS equivalent
Forgot to add, benefits include
- don't have to remember to update a database
- will run 'over the top' of a stanav or other app like Google Maps, Waze, Spotify...
- can be configured not to warn you unless you're actually approaching a camera above it's speed limit (knows the speed limit)
- can warn you when you're over the speed limit regardless of cameras - good should you want to change your speeding behaviour
It's not 100% (but what its?)
- I've noticed a few of the speed limits (not the cameras, so far) are wrong
- You prob need to be using/powering your phone in your car already (for music/satnav etc), though it will work off the phone's battery
- It DOES use data, but not a lot (depending on the mode you use it in)
- Doesn't seem to audibly alert if I speed over the limit only between the app's trigger distance and the actual camera (i.e. accelerating), though the popup always appears. (I choose no audio alterts unless I'm over the speed limit)
Not a brilliant set of reviews on Amazon, but obviously your experience has been good
Amazon
Owned the K2 and since changing to a FL A3 I changed to a K3 also, never had an issue to be honest.
Reactions: azibux1
Will have a look later tonight and see if I have experienced anything thats been reported. Will also pop out and grab the unit from the car and load up its software and take some screen caps.
Reactions: azibux1 and samo26
I use a cheetah c550 which is really good and plugs in to the 12 v socket, free updates ect. I have it on the dashboard but occasionally I put it in the armrest and it still picks up the cams. Lot more expensive though than the K3 which does look very good.
Had a fast read through a good number of the 1 star reviews on Amazon, 21, and have never experienced any of the issues myself... well other than slow GPS satellite acquisition and the odd false alarm, maybe for an old camera. Been using Inforad for approx 4 years now.
Reactions: azibux1
I've had one of those for some time with no issues.
Reactions: azibux1
Exactly, correct. Only really good for static positions.
Got one built into my dash cam Also gives you the option of pushing a button as you pass the mobile ones to store/remind you the next time you're in the area.
43
5K
SuperflyTNT1974
S
