Its always the little things that p**s me off - Help
SinkyA3
Preston
ok so im at my wits end. My drivers door packed up on me. i.e would not lock with the fob but locked the rest of the doors. found it to be 2 broken wires where the door opens, fixed the wires.. door working fine... GREAT. then go to start the car and the battery is dead. lucky i had a spare battery while i charge that one..
recently found out that the button i have on the side of the door card (something like a motion sensor i.e for when a dog is in the car and the car is locked the alarm wont go off) that button is not working, also when i open my drivers door my interior light does not come on anymore and it also does not display on the dash that the door is open.. passenger side is fine no problems.
managed to find a local guy with vcds who plugged into my car and found a fault saying DOOR CONTROL MODULE;DRIVER SIDE - NO SIGNAL/COMMUNICATION - INTERMITTENT
checked the wiring and i cant find any more broken wires
any ideas of what it could be??
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
Component: RNS-E HIGH EU H74 0600
Revision: 04S Serial number: AUZBZ7G0911500
Coding: 0209717
Shop #: WSC 00441 210 91426
VCID: 387F38824BE6328137-806C
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 2
Reset counter: 190
Mileage: 98321 km
Time Indication: 0
Date: 2013.07.17
Time: 19:35:30
Freeze Frame:
Voltage: 10.60 V
Mileage: 144560 km
Count: 1601
Clock: 17:01
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 5
Reset counter: 184
Mileage: 143259 km
Time Indication: 0
Date: 2016.12.03
Time: 21:26:28
Freeze Frame:
Mileage: 144460 km
Count: 1301
Clock: 00:08
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 190
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 01:36:56
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0420
Revision: 093439 Serial number: 8P0820043AH
Shop #: WSC 06314 000 00000
VCID: 72EBCAAA6D1A98D1C9-8026
3 Faults Found:
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:45
Freeze Frame:
ON
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:15
Freeze Frame:
Temperature: 7.5�C
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 116961 km
Time Indication: 0
Date: 2015.03.18
Time: 05:24:20
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007403389
Coding: 018C0F07A0141000470000000000000000085E175C010000000000000000
Shop #: WSC 06435 000 08192
VCID: 458141760C145F69BC-8010
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00055568
Shop #: WSC 06435
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 17
Reset counter: 189
Mileage: 142752 km
Time Indication: 0
Date: 2016.11.19
Time: 19:49:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:00
Freeze Frame:
ON
Voltage: 14.50 V
ON
ON
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 189
Mileage: 144419 km
Time Indication: 0
Date: 2017.01.08
Time: 09:49:00
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
OFF
OFF
OFF
OFF
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
VCID: 41895566183C734980-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
2 Faults Found:
01303 - Unlicensed Version. Not all DTCs
004 - will be decoded. - Intermittent
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0771882BA
Coding: E9821F0E4006020101
VCID: 306F00A2A396EAC17F-8064
7 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 40
Mileage: 139252 km
Time Indication: 0
Date: 2016.08.06
Time: 08:34:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 00:00:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:02
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
01324 - Control Module for All Wheel Drive (J492)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
Coding: 0209717
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 190
Mileage: 98321 km
Time Indication: 0
Date: 2013.07.17
Time: 19:35:30
Freeze Frame:
Voltage: 10.60 V
Mileage: 144560 km
Count: 1601
Clock: 17:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 184
Mileage: 143259 km
Time Indication: 0
Date: 2016.12.03
Time: 21:26:28
Freeze Frame:
Mileage: 144460 km
Count: 1301
Clock: 00:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 190
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 01:36:56
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0000560
Shop #: WSC 00441 210 88110
VCID: 428B5A6A1D3A685199-8016
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000560
VCID: 44875C72072E6661AB-8010
1 Fault Found:
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209717
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 190
Mileage: 98321 km
Time Indication: 0
Date: 2013.07.17
Time: 19:35:30
Freeze Frame:
Voltage: 10.60 V
Mileage: 144560 km
Count: 1601
Clock: 17:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 184
Mileage: 143259 km
Time Indication: 0
Date: 2016.12.03
Time: 21:26:28
Freeze Frame:
Mileage: 144460 km
Count: 1301
Clock: 00:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 190
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 01:36:56
please can someone shed any light?
thanks
