overrated - underated
So it wont stomp all over it then?Cant even beat it to 60.Can the S3 beat one to 100?
anyways, as stated by Silver this thread has gone on enough of a tangent, sorry Silver, I have said my piece.
End of.
overrated IMO
diesel cars
max power/fast car mag
ebay
PSP's
BMW's
underated IMO
subaru's
chip's n cheese
michelle marsh
vectra gsi's
may the list go on....................
All 4 by 4 cosworth cars had 200 block based engines as standard fit the two wheel drive versions didnt bar the RS500.
So what you are saying is that my 4 by 4 saff didnt have a 200 block as standard ?
I think you are getting confused a 200 block doesnt come from an RS200 as you claim all 4wd drive cars had the strengthened block designated and stamped with the marking 200 all rear wheel drive variants bar the RS500 had the 205 block which was not as strong as the the 200.
So judging by your first comment it seems its not everyone else bullsh1tting maybe its you ? And it would appear that NASA could well be landing on the sun given the fact that you are a self proclaimed Ford Trained Cosworth Expert
The YB series
The YB series of engines are based on the older Pinto engine block and were introduced in the road-going Ford Sierra Cosworth in 1986 with 204 bhp. It was the first road going engine that developed more than 100 bhp per litre, with 5,000 units built for homologation purposes in Group A, both for rallies and touring cars. Racing versions could develop about 400 bhp. A limited edition evolution model was introduced in 1987, the RS500, with power now exceeding 550 bhp in full racing trim. Today there are many road going YB engines developing over 750 bhp and there are several rallycross Sierra Cosworths utilising YB engines tuned to over 900 bhp.
Further evolutions of the YB included a reduced-emissions road version, as well as the block used in the Escort Cosworth (which used the Sierra floorpan). The engine stopped being used on new cars in 1997, with the Focus WRC and road-going Focus RS relying on Zetec designs.
And more
http://www.rallycars.com/Cars/Cosworth/Cosworth2.html
I know more about Fords than i need to now thanks!!
Please let this be the end
Underrated
The cosworth Rs500 block
you really a complete numpty mate the RS500 has an engine based on a 200 block the strengthened Cosworth block that was adopted and used at a later date for all 4 wheel drive cars but first featured on the RS500 . You claim it comes from an RS200 car in your earlier post Even the link you posted makes refernece to the RS500's thick walled block THIS IS KNOWN AND MARKED AS A 200 BLOCK NOT AN RS500 BLOCK
There is no such thing as an RS500 block there is of course such a thing as an RS500 car WHICH HAD A 200 SERIES THICK WALL BLOCK IN IT
you really are a complete fool
THE YB COSWORTH ENGINE
1993 cubic centimetres in capacity, derived from the SOHC Pinto which with modifications can run an easy 190bhp on it's own, without the use of a turbo. So the pinto was a good basis for a performance engine. Cosworth started work and manufactured a 16 valve DOHC head; they then bolted this to a 2 litre pinto block with reinforcements, such as heavier casting stronger bores and different oil way drillings. With a lower compression ratio off 8.0:1. Early blocks are marked 205 on the side, later ones 200 but these were only fitted to the 4x4 not the 2wd. With the use of a Weber fuel injection system and Garrett T3 turbo charger, this engine was producing upwards in the region of 300bhp. Ok for racing but far to lively for the company car drivers of the mid 80s. So with some serious down tuning they got it to produce 203bhp & 205lbf of torque. This was coupled with a T5 mustang gearbox and fitted to the sierra. Which lead to a car which today is still sought after.
Why are you posting links to pictures of RS500's ? what have they got to do with your idiotic claims ? of bullshitting and Nasa
I am going to give up too.
Its not an RS 200 block its not an RS500 its just a nice and simple 200 or 205 block.
In the meantime I look forward to NASA announcing they have landed onthe sun
F**kin no i dont this is taken from cosworth history page on the net...you better tell them they are wrong as well
After the RS500 there was an empty slot in the Ford motorsport department. They needed a new car to keep up with the Lancia Delta HF Integrale and the Audi Quattro. This lead to the development of the 4-door Sierra RS Cosworth 4wd. It looked very similar to the Saphire 2wd, but underneath the body the changes very many. It had Ferguson 4 wheel drive system with two viscous couplers; one on the center diff, the other on the rear diff. Torque split was 34% to the front and 66% to the rear wheels. The engine was improved, having changed 80% of the parts compared to the Saphire Cosworth. The changes included new modified RS500 block, stronger head and stronger pistons with new gudgeon pin placement to decrease piston slap. A new Garrett T03 turbo, new intake manifold and bigger intercooler was also installed. This lead to a powerincrease of only 224hp, but much more was available when tuning the engine. But none the less; it still did not fulfill Ford's expectations. It did not score a single group A win in it's two years of rallying. The reason the Sierra Saphire didn't produce any decent results was probably due to it's weight and size. Ford simply needed a smaller car. The suitable model for the time was the Escort.
I have now come to the conculision you are a wind up merchant or you have lost the abilty to intake information
Have a nice day
One thing you have made me laugh
Lol You are absolutley right the RS500 engine did have its own specific thickwall block at the time designed for motorsport and homologation purposes.
The code number for the RS500 block was 200 (call it a part number if you like) and became known at a later date as a 200 block. Some years later Ford saw fit to replace the standard block designated 205 as fitted to the original 3door sierra and RWD saff with the 200 block for all 4WD drive cosworth vehicles.
It really is quite simple nothing to do with Nasa , RS200's, dodgy wiring looms or ******** just the part number 200
Make your own minds up...........
YB Series Ford Sierra Engine
Type Year Size Output Description
YAA 1984 1993cc ? In-house project, 16 vaslve, twin cam belt drive on Pinto block for small manufacturers, 3 built
YBA 1984 1993cc 200 Bhp. Prototype YBB, 10 built
YBB 1985 1993cc 204 Bhp. Turbo YAA commissioned by Ford for Sierra RS Cosworth, 5000 built for homologation
YBC 1986 1993cc 280-300Bhp. Group A rally engine
YBD 1987 1993cc 225 Bhp. Evolution YBB used in Sierra RS500, more turbo, 8 injectors, 500 Bhp in race tune
YBE 1987 1993cc -- Ford Undustrial Customer Engine, non-Cosworth covers, used in Panther Solo
YBF 1987 1993cc 400+ Bhp. Race version of YBD
YBG 1989 1993cc 207 Bhp. U.S. emmissions capable model
YBH 1989 -- -- not yet disclosed
YBJ 1989 1993cc 207 Bhp. Similar to YBG, emmissions engine
james0808 said:
YBD is Rs500.
Absolutley correct
Ford needed an engine desperately to regain it's credibility on the racetrack, and when they just happened to drop in at Cosworth, they spied an equipped engine. It was suggested that they took the YAA and fitted a turbo. Hence the Sierra Cosworth was born in 1986, with 204 bhp. This engine was built from selected Sierra injection blocks and, therefore had the same cast-in markings. They made 5500 of these, now called YBB engines, 500 of which were sneaked off for another project. These were to become RS500's, from which the Touring Cars were produced. These cars had engines now producing 225 bhp, (bigger turbo, more injectors) labeled YBD, that was in 1987. To produce these machines, the engines were whipped out and replaced with a thicker walled Motorsport block (distinguished by 1 in. as opposed to 2.25 in. core plugs) These engines are distinguished by green rocker covers, the larger core plugs and "200" was cast into these blocks.
I am still waiting to hear of confirmation that NASA have landed on the sun A4Quattro.
This has been a very informative thread about cosworth YB engines.You learn something new every day.
I know to much about Ford Engines now i feel violated.....I am away to the samartians im in pieces
You do indeed dont buy one unless you have very deep pockets as I found out even with a reinforced 200 ****** block !!!!!!!!!!!!
Is that the one out of an RS200.
Anyway I stand buy my original statement that the Escort Cosworth is an under rated car.
Enjoy reading the spec of these ESCORT COSWORTH ENGINES A4 Quattro
24 Oct 06
Escort Cosworth engines
Essex 1) WRC engine Tommy field spec, WRC motor sport 200 block, accralite pocketed pistons, BD 15 cams, WRC polished & ported head, 8 injection inlet manifold, big wing baffled sump, ALS spec, newly rebuilt never run £8500.
2) GPA cosworth engine, fully rebuilt, with motor sport 200 long studded block, ported head, WRC head gasket, BD14 cams, WRC 8 injector inlet manifold and fuel rail, New motor sport turbo for ALS, high pressure oil pump with oil spray system, lightened and balanced crank, new water pump, big wing baffled alloy sump, motor sport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, all new seals and bearings £6500.
3) Mountune spec clubman GPA cosworth engine, fully rebuilt, with motor sport 200 long studded block, WRC head gasket, New motor sport ALS turbo, high torque exhaust manifold, 4 grey injectors, ALS throttle body, high pressure oil pump with oil spray system, lightened and balanced crank and rods, new water pump, big wing baffled alloy sump, motor sport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, AP paddle clutch £4800.
Sorry, what was this thread about?!?!?!?!
LOL @ the Ford haters and marque elititists
Well, I have a 300bhp Audi S4, but my mate's loopy Escort Cosworth makes me want to mess myself and throw the Audi in the bin.
IMO (and experience), Escort Cosworths are awesome. They are really only an Escort by name.
As for modern hatches stomping all over them,......well against a standard one in the dry yes possibly. But, the Cosworth has absolutely HUUUUUUUUGE potential, the sort that most hot hatches could only dream of.
Some of you may recognise the car .......................
Does he realise his missus has left her ironing board on the back of it?
silver75 said:
they completely ruined my thread
well lets get back on topic then
Overrated:
Footballers - it's not rocket science now is it
This one might cause some controversy but here goes - Princess Diana - yes it was tragic but it's been a very long time now, can't we respect her memory enough to stop bringing this storey up in the news again and again!
Also - Sorry but I can't agree with whoever said golf was overrated - i love the game to bits although some of the people who play it are complete w@nkers
underrated :
Danni minogue - definitely - she’s a babe, grrr
VW corrados - really good looking car IMO, just looks purposeful
Golf is overrated as a sport, because it isn't a sport, it's a pastime, like darts or snooker, plain & simple.
A sport requires that some level of physical fitness will determine the outcome, not just skill.
Also playing against yourself is tantamount to w@nking so no real surprise it's full of w@nkers really.
Overrated
Bo ****** Selector
Designer anything
Underrated
Head massages
Fresh bedding
Sleep
Quickies
AndyMac said:
Overrated
Bo ****** Selector
Designer anything
Underrated
Head massages
Fresh bedding
Sleep
Quickies
Fresh bed sheets!!!!
