Just looking some advice. I have read a lot on different threads of people changing there rods. At what stage should these be changed and is there a certain make that they should be changed to for more reliability?
At the age of the 1.8t then rod lottery can happen at any time arguably... if the level of tune is sensible and boost not brought in with a whack then it stands a chance but if you want to have piece of mind and get the most out of your hardware then rods are advised... they are a pre-requisit if changing the std turbo to a hybrid...
Integrated Engineering rods are amoung the best out there... only fit rifle drilled rods though... S3's use 20mm pins (I say this as if you search for rods there are 19mm ones too)
http://badger5.biz/epages/3927bc2c-6485-4739-96a5-d6cca869fcd6.sf/en_GB/?ObjectPath=/Shops/3927bc2c-6485-4739-96a5-d6cca869fcd6/Products/"RD144 rods"
<tuffty/>
What is the opinion on these http://www.performancebyie.com/inte...can-144x20-rods-1-8t-fsi-16v-early-8v-audi-vw ?
I have them in my setup, so far so good, IE write they have been tested in applications over 1000hp, but I have no experience on different rods myself so I just wonder.
other than not rifle drilled....................
your money
your car
your choice what to spend on what...........
What spec do I need for an Agu? 19 or 20mm?
144 x 20 for aguWhat spec do I need for an Agu? 19 or 20mm?
no rod bolts included in the listing - bewareLook at this on eBay:
https://www.ebay.co.uk/itm/322313918610
Audi / VW 1.8T -- RIFLE DRILLED -- forged rods ** PRISM ** H-Schaft Pleuel
Any advice on these?
staying at 234bhp if so std rods are fine for that levelThank you all very much for your sound advice. I'm in a challenge as to where best to invest my limited amount of funds. I currently have an a3 8l 1.8t Agu with 234bhp to my knowledge (this was what I was told upon purchase) I want to go into track days and I feel as I'm going to be pushing the engine it would benefit from sound internals. On this basis which is my best option considering funds are short...?
Thoughts and opinions welcomed =]
