Oil in spark plug holes
Pasteurised
Hey guys, changing my spark plugs and the ends of the coilpacks are soaked in oil on 3 cylinders.
It looks to be coming from where the rocker meets the head inside the spark plug holes.
Will this just be the rocker gasket causing this?
Just replace it, inner and outer rocker cover set
If you replace these gaskets I suggest you go for genuine ones. Replaced mine including timing chain tensioner gasket with aftermarket ones off eBay and It it leaks worse than it did before!
