JohnDuh
- Joined
- Aug 18, 2016
- Messages
- 160
- Reaction score
- 26
- Points
- 28
- Age
- 45
The other day we did a compression test on my engine (APY) with 282000km. (pic for proof )
The results were 175psi on all cylinders, so if the internet didn't lie this means a rather healthy engine.
The downside is we also found where my oil is going. The chargepipe (gray metal tube coming of the turbo) was full of oil. As in run your finger down the pipe and you can almost flick the oil away.
So my educated (not so actually) guess would be that the oil seal in the turbo is shot and needs replacing, which brings me to the actual questions
First the easy ones :
1. is rebuilding a turbo hard ? I've seen rebuild kits online and they are rather cheap. Also watched some youtube videos and it doesn't seem to hard, but I'd like to have the opinion of somebody who actually did a rebuild.
2. How long does a turbo rebuild take. Since this is my daily car, I would like to be reassured I can pull it off in a weekend. This includes getting the turbo out of the car and reinstalling it.
3. Is there any other job I should do "while i'm in there anyway" ? I've seen the flexible part of the downpipe is frayed, so I probably should replace that, right ?
Now the harder ones :
Since the turbo is shot, I can man-math myself in an upgrade. For the moment the car is bone stock, so we have a blank slate here.
I should also state that I would prefer not to open the engine, which means limiting myself to 275hp to keep the rods happy.
Also my previous car was a Ford ST (diesel 185hp) which I really enjoyed due to it's unbelievable handling. So I would rather get the S3 to handle instead of throwing a lot of money at making it go fast in a straight line.
4. Do I need another turbo to get to 275hp. The internet seems to think I don't, what do you guys think
5. I've read a bit about ball bearing turbos. Are these worth it, i.e. with my performance goals in mind will I feel a difference in spool time, or will this be negligible ?
6. Are there any upgraded turbo's that are bolt on? (I don't have access to a welding shop, so can't make my own DP) I've read a bit about hybrid K04 turbo's, which seem to be aimed at more hp, which in my case is not (yet) the goal.
Thanks for reading this long post and thanks in advance for educating me
