Hey Guys and Girls,
I'm a new S3 owner and I think I'm in a spot of troubleshooting hell, I don't know which way to head in my theory of this cars operation, the symptoms I'm getting are:
Rough cold starting problem, overfuelling on cold start, takes about 2 primes of fuel pump to start
boost gauge reading -12inHG for approx 2 mins, idle at 1350-1250rpm, then goes to -20inHG and idle is at 810rpm (a/c on)
hesitation on driving in this time (i know, just wait 2 mins right, although didn't have to on my Nissan 32GTR or Lancer Evo 8)
I bought this awesome little car about a year and a bit ago, but since there was no history with it, it was a bit of a risk, but you couldn't go wrong with an audi right? I've had to do countless repairs which includes replacement of the engine due to the big end bearings failing due to excessive high boost pressure & poor maintenance @160k kms which is unheard of from anyone right?
The modifications it came with when I bought it were:
Forge 007 DV
Forge TIP
Forge Boost Piping
Manual Boost Controller
FMIC
Modified cold air intake to Air Filter with K&N filter
Full exhaust system
Boost set at 19PSI, standard 8.6 PSI
APR stage 1 tune
So far I have replaced:
BAM engine
all lifters
Oil pump & pick up
Upper Cam chain tensioner
Cam cover gaskets
Clutch & Flywheel
n75j to f model
multiple vacuum pipes
timing belt
tensioner, rollers, bearings
water pump (metal impeller)
thermostat & elbow
expansion tank
Fuel Filter
Plugs
Oil filter & oil every 5k
Now things are starting to frustrate me, on these cold starts, could it be a MAF sensor, running rich etc or the coolant temp sensor not reading correctly, until the temperature comes up a bit, bad 02 sensor, or a blocked PCV valve/breather system fault/leak
I'm an Aircraft mechanical technician and not afraid to leap into something but for all the things I've done or had done already, I thought she'd be banging like a champ by now.
any help or advice on what to do next would be greatly appreciated,
thanks guys
3v0
Forge 007 DV
Forge TIP
Forge Boost Piping
FMIC
Full exhaust system
APR stage 1 tune
BAM engine
all lifters
Oil pump & pick up
Cam cover gaskets
Clutch & Flywheel
n75j to f model
timing belt
thermostat & elbow
expansion tank
Fuel Filter
Plugs
thanks guys
3v0
