On the S3 its there to open the 2nd pipe at different time, full throttle, idle etc.
So yes not needed on your new system, poke a screw and a bit of sealant in it.
If you lie on the ground and look up in between the exhaust tail pipes near the rear silencer, you will see a small vertical rod attached to a lever on the outer pipe at the bottom and leading up to plastic vacuum operated valve above the pipe. The idea is that the valve opens and closes a flap in the exhaust pipe to comply with noise regulations. The valve is operated by a black rubber vacuum pipe about the thickness of a thick pencil. When fitting an aftermarket exhaust, folks block it up and cable tie it out of the way. Some people seal it with a screw or a golf tee.
