KristoffV6
- Joined
- Mar 19, 2015
- Messages
- 24
- Reaction score
- 3
- Points
- 3
Gave the car a full detail today and noticed a small pool of fluid on the floor under the engine bay when I moved the car back into its normal space. The fuel was clearly diesel.
I whipped the engine cover off and the area around the high pressure fuel pump had standing fuel present in bolt holes etc.. so I knew something was wrong, there is clearly a leak somewhere. Went to star the car again...... and it wont start, it just turns over. When turning over fuel is clearly leaking from the high pressure fixing circled in the image below.
It's not squirting out at high pressure, but it's definitely leaking out of that pipe fixing. I took the fixing off and cleaned it up and re-tightened it. No difference, car still won't start and fuel is still leaking from there.
Any idea what the problem is? Do these high pressure fixings wear? Seems unlikely to me. Would too much pressure in the system cause a leak at that point? Has there been some failure of the fuel pump do we think?
I'm at a bit of a loss and I've got a bit of a problem as I can't getting down my steep drive to take it to be looked at if it won't start.
