BBS Speedline Help
Lowry_uk
Age
40
Hi Guys
I have just found and purchased some 19" BBS Speedlines
Specs are
8.5J Wide
Et 48
As they haven't arrived yet I'm a little curious as to whether these will fit now. I've got an 2005 B7 Avant
Cheers for help in advance
What size are your front brake discs?
Mine touched the calliper faces and I have to use 3mm spacers to clear it
FYI I'm running same wheels
They are the exact same specs as my Speedlines. They fit perfectly on my car. As @sline29 said above check your caliper clearance, I had the same problem when I changed my pads the caliper stuck out more than before and meant I had to put spacers on the front. I didn't mind too much as I have it lowered on coilovers with 20mm spacers on the back and 10mm spacers on the front, gives it a real nice wide stance - check out my thread on this to see how it looks. They look amazing on this car!
thanks a lot guys
What tyres sizes are you both running??
I'm running 235-35-19
But I think Sean is running 225
My calipers are standard black I think
My car is the bul 220bhp engine so have larger discs as standard
10
9K
J
10
19K
