After some testing it works with sidelights on and also with headlights, soon as you brake, the bulb warning comes up for the outer n/s but the brake lights work fine.
Just off to scan it.
Give the plug a spray with WD40, the water and corrosion will run out after about 5mins, then dry out the gunk with a rag. Also give the metal contacts a gentle burnish with a pin.
