S3Sallie
Hi all,
Here's my situation. Narrowed down the issue and realized I have a haldex that's acting up.
When I start the car, for the first i would say 500m - 1km i have what feels like a power loss and the traction control light flickers. no boost. There after, things kind of iron out and the car drives normally.
I've gone through this document as a guide but can't figure my issue out
http://www.vaglinks.com/Docs/Audi/TT/Audi_TT_Haldex_SelfStudyGuide.pdf
After investigating the issue. I unplugged fuse 31 (haldex) the car drives normally from the get go.
Troubleshooting so far.
>Diff oil change done around 20 000kms prior.
>Haldex oil Changed regularly (10 000kms). Done another service with the filter change.
>Maf sensor readings are good on measuring blocks
>Changed brake pedal sensor
>Measuring blocks on 051 AWD all reflecting correctly, precharge, brake switches etc
>changed cam position sensor
>Had side shafts and prop checked
I've never had this issue. The car has been running real good. Definitely feels as though the wheels are dragging and consumption is noticeably more when the haldex is connected. But even so, i would think that the jerking/low power issue should be there constantly. It clears out and power returns to normal?
i don't get any lock ups on the full turning circle also no weird noises.
Its definitely got to do with the haldex/AWD system. Can anyone shed some light?
