DIS Oil Temp display is blank / showing null
lincoln_dj
Active Member
Lincoln, England.
Hi,
I'm 99.9% certain the temperature used to display when I went to check it via the DIS but whenever I look now it just shows "---". It was blank with my original red DIS and is still blank with the facelift S3 black/white cluster I've had fitted. It's a '57 S3.
I did wonder if it was because my service reminder had been reset to fixed interval - since oil temp is used to calculate variable service and maybe was now no longr monitored by the cluster. I've tried resetting to fixed schedule again but to no avail.
Is there anything else I can check/change with VCDS please? Hopeful it's just a setting!
checked with VCDS and oil temp is showing as minus 60°c, so I'm assuming the oil temperature sensor is faulty / wiring issue. I don't have any fault codes though?
Anyway, should my car defo have oil temperature? if so, any ideas where it's located? cheers
On my car you can see oil temp on the DIS under 'check'
i meant where is the sensor located. obviously I know where it is on the DIS as I included a photo of it
Reactions: Daveyonthemove
ok. guess i gotta brave the wind and get the under tray off to have a look then! cheers
Reactions: Ryan Wilson
Hi mate ,
I’ve discovered same problem my car is reading -60 on Vag com , and just lines on oil time on the dash board , did you manage to fix this and we’re is the oil temp sensor ?
H
15
4K
S.
