hollows wife
night before last after dropping daughter off in rotherham , i nipped to garage to refuel , when i was pulling ot of garage rado reception was terrible (capital radio) at first i thought it was the canopy over the garage that was causing interference , but within 24 hours t seems ive lost all fm radio reception ,unless the car is parked . then it seems to work fine ,i also seem to be ble to get some reception if im on higher ground,coutryside were no buildings are present.
stripped boot down no water marks ,rear wiper works fine with no leaks or water ingress around motor , unplugged both amplifiers large one and th small one at the top of the screen ,checked for damaged ,losse ,corroded pins and nothing.
plugged them back in ,reception working fine till car is driven then no fm reception at all . mwand lw work fine though .
swapped amps with inlaws 2012 model ,still the same . wife just been out and says reception is back but sketchy.
dont fancy buying new amps straight away as done this before with older 09 plate and made no difference .
anyone ever had a snapped cable in to of tailgate before ? as i know they feed through into roof it an ackward angle and probably a pia to work with .
