Revo Remap Group Buy Discount!
Guys, here is list. If you going to do this. Please copy and paste so we have accurate numbers please.
  1. RS4K - 2010 S3 2.0T - Watford
  2. AU11 ALS - 2010 1.8T A3 - Amersham (nearest MDM Technik but will travel)
  3. mattwez378 - 2012 RS3 2.5T - Blackpool/Ramsgate/Hastings (I travel a lot)
Reactions: Revo Steve-W
4. Doberman steve - 2008 s3 2.0T - Eastbourne
I'm replying about the stage 2 remap, also my car is a 2.0tdi. Would that be a problem?
Very tempting... I might be interested in this. I will add my name to the list shortly.
@Revo Steve-W is it soon enough to get this group buy or will you honor the the 20% at a later date. Cheers
5. Craig-P - 2009 S3 2.0T (Working towards stage 2+) - Carlisle
whats the damage on a c6 rs6 remap and do you offer a gearbox remap for them ?
I'm getting mine done at end of month anyway so this won't benefit me unless it's all for before end of this month.
no love for the PD170 on the site
If it's the PPD, then leave it stock. people do offer tuning and DPF delete, however in our experience they are floored from factory and tuning will cause more issues in the long term due to the inherent design limitations of this Engine, the Diesel Particulate Filter and the flawed factory regeneration process, Revo do not offer software for any PD170 DPF application.
DPF: In simple terms (as VW put it) the Diesel Particulate filter is part of the exhaust system responsible for cleaning the engine exhaust gases before they enter the atmosphere.
DPF Function and Problems
The DPF function is to collect soot particles emitted in the exhaust gases. At a predetermined level the DPF supposedly ‘cleans’ itself by a DPF regeneration, a process that increases the temperature with the DPF and burns off the soot particles.
In theory the vehicle should be able to carry out its regeneration process un-aided under normal driving conditions. However in practice the majority of owners find this isn’t the case and will be told by their main dealer that their driving style is not sufficient for the process to function and that the car needs to then be driven a certain way to clear the DPF. VW group documentation says that ‘short’ or ‘stop/start’ journeys aren’t sufficient and the regeneration process may not complete. We know of customers that have been advised by the VW Group that they do ‘too many motorway miles’ for the regeneration to function correctly. VW Group documentation states:
‘Driving conditions in inner-city and any UK Island do not proved optimum conditions for the regeneration procedure’
‘Consider your driving style and length of journey to allow for the driving conditions required for DPF regeneration’ refer to owners handbook.
In a lot of scenarios the regeneration procedure doesn’t complete and allows the DPF to further block and require forced regeneration or DPF failure and replacement; something that’s not usually covered under warranty.
NOTE: the issues with this engine are mainly related to the regeneration process, this process was refined and functions without issue on the PD140 and later CR engines which Revo Fully Support
Performance software and DPF
Problems occur when the cars run performance software for the same reasons they occur in standard vehicles, however depending on the driving style these problems can be accentuated when using performance software.
The DPF can block or get too hot causing hesitation and poor fuel economy. Although Revo haven’t had any dealers or customers experience it, there have been reports in the press of dry DPF systems actually catching fire. Issues experienced are typically erratic power delivery and fluctuating fuel economy.
For the above reasons and the inconsistency with these engines Revo has decided not to offer software for any PD170 DPF application.
NOTE: this only effects the PPD170 not other diesel applications that Revo offer software solutions for
DPF Bypass
We spent a lot of time looking at potential solutions for this engine, including a DPF bypass solution in the form of an aftermarket downpipe and specific software. We thoroughly tested a DPF bypass setup over an 18 month period before coming to the decision to not support this product.
NOTE: There are no issues with the PD140 DPF vehicles, or later CR (Common Rail) Engines. Revo fully support these vehicles.
Reactions: Sandra
Iv already had my revo stage 1 done last week. I want my gearbox done but unfortunately the Autosport discount doesn't apply to dsg software
I wanted too but couldn't afford it all at the same time as would have been expensive
I've been looking at the Revo website, and it states that the remap for mine is only suitable for off road. And that bypassing the DPF will mean it'll fail an MOT. So I don't think it's wise I have it done, sorry. Thanks anyway.
6. Slovicej8 - 2005 A3 2.0T - Cardiff/Tredegar (going for stage 2)
7. Burgos3 - 2012 S3 2.0T - Manchester Stage 2 +, need to do the hpfp
8. Nige A3 - 2012 A3 2.0TD 140 - Portsmouth
Reactions: Sandra
Nearly there guys if we can get two more we should be able to do this as soon as possible. Spread the word!
DSG maps are included!
If that's the case....
9. leshkin - 2009 S3 2.0T (non-Revo Stg2+) - Uxbridge, DSG Transmission Software Stage 1 map
Hi guys, sorry but I've just had a call from work and have to go the states until the start of April tomorrow so unfortunately I'll have to come off the list.
No worries mate enjoy your trip..
Updated list:
7. Nige A3 - 2012 A3 2.0TD 140 - Portsmouth
8. leshkin - 2009 S3 2.0T (non-Revo Stg2+) - Uxbridge, DSG Transmission Software Stage 1 map
If it turns out to be SCC in St Albans, Im definitely in!
9. general_zod - 2006 A3 2.0T - Stevenage
Yeah quicker than i expected, hopefully we can get one more person this week and then confirm a booking
My only concern is that we're all quite far apart and if REVO want everyone booking with the same reseller for the work, then I will probably not want to travel too far to get this done.
This is my concern tbh.
Ideally I'd like to go to R Tech which isnt really close to me but the the amount of good feedback I'm see'ing/reading seem's worth it..
I'm wanting a revo stage 1,for my a3 2010 tdi, count me in!
10. Manny1980- revo stage 1,for my a3 2010 tdi,
There seems to be a lot down south,I'm in leeds,been wanting to get this done for a while now, maybe we could meet half way!
I am sure we can arrange something but will be hard to accomodate for everyone as i am sure you can understand. we can try and find a location roughly central but it may require travelling more for some than others. there seems to be around 7+ of us in the south and rest spread around. I am sure Steve will be able to help us out.
Reactions: Sandra
That's sound yeah,do you know roughly what it would be for a stage 1 for my car,I was told it would be around the 300 mark,without discount. Is that about right,cheers fella
If you check out the pricing on the revo site, take 20% off then add the 20% vat, that will be your price
