Boot lid problem
JohnStan725
Midlands
Guys needing some help probably a straight forward fix but whilst driving on the dash it constantly saying that my boot is open little icon flashing. when it's definitely closed, I'm thinking the sensor on the boot is broken can any let me know if they had anything like this before?
I had this problem when we first got the car.
Your right, the sensor is intergrated into the locking mech of the car and you will need to buy a new lock.
They are quite cheap.
The reason it goes is because the liquid from the washer bottle drip down onto the lock and in time the sensor fails.
The cure we found was never to use the rear washer but just the wiper.
I blocked the end of the pipe off further down with a bolt stuck down the hole.
As for refitting a new lock this I found tricky.
You need to remove the interior panel on the hatch.
Then atttcah new lock.
Climb into the boot with rear seats down and get someone to close the hatch.
That way you can position the lock, so when shut push the lock upwards so it is just holding the ring, so that you get a secure lock then climb out and unscrew the rubber bumpers either side so there is no lateral movement on the boot lid.
If not done the lid tends to bounce on the lock.
Reactions: JohnStan725
Dom, thank you didn't think anyone was going to reply. Really appreciate this can you confirm the sensor is where the wiper motor is behind the boot trim? Hopefully there's part numbers so I can find a new part as this is really annoying when I'm driving keeps coming on and off! Thanks for letting me know I have dewipered my car probably the bung is no good and letting some water in or it could be the bass rocking the sensor! But thank you again Dom will attempt this!
You need to remove that big black panel which just pops on.
The sensor mech is inside the locking plate which is held on with a couple of screws
Unfortunatley you need to replace the whole thing as the locking plate is a sealed unit.
Ditto - my rear washer hose kept popping off every few months or so and each time I would try and fix it a bit better to make sure it lasted longer. Eventually it went all together and I ended up repairing it by attaching some old rubber fuel pipe from my karting days between the motor connector and the plastic hose line built into the boot structure. Many high quality pull ties were used to secure it on as tightly as possible and since then it's not broken or popped off since so it is possible to repair it if you ever want to get the rear washer function back.
I had the same problem but before I bought a new lock, I sprayed the lock mech with penetration spray for seized blots etc, that worked a treat on mine and had no problems since, might be worth a try before buying a new lock if you haven't already.
All sorted now guys was definitely water causing the problem, the sensor connection was soaked, dryed it out unplugged it for a day and it's been okay since. It was the bung letting water through cause of the cold weather. Sealed now though so all good! Thanks again everyone
13
473
894
885
