ACC when approaching stationary traffic - oops !
mls
I use ACC a lot, and I like it. I live in London so I'm pretty much always in traffic, so the stop start feature is great - I have the S-tronic S3 Sportback.
I have found recently, that when I'm on an empty stretch of road and the acc is driving at its (say 40mph) setting for a while, it does not seem to see stationary car infront when I come to a traffic light for example. No green icon appears on the dash to say that it can sense a car infront, and it just keeps going.
I leave it to the last minute, then brake to avoid hitting the car.. but shouldn't the ACC sense the stationary car and slow down/stop accordingly ?
Has anyone else had this ?
If you change your DIS screen to 'Assist' you should see your car at the bottom and some horizontal lines above it.
As you approach a car, you should see another car appear at the top
ie,
TARGET CAR
YOUR CAR
which shows that the system has detected a car in front. As you approach there are two arrows either side of the horizontal lines which should get closer to the middle green section then once they go towards the red section the car should brake automatically.
Can you confirm your car is actually detecting the car in front using this screen?
Thank you ! As always this forum is so informative.
Just checked in the manual and you're quite right @veeeight - only objects that have been previously detected as moving will be tracked.
Hmmm.....think I might get my old dashcam out of the cupboard and put it on the rear window after reading this Thread.
Don't fancy being rear-ended by some Audi Driver who thinks their car is going to brake - and doesn't.
:ambulance:
Reactions: Grover, Ignition1, JohnM100 and 3 others
I also read this in the manual and was going to test it with a cardboard (somehow) but now I don't need to. Cheers :)
But I believe that if you are doing less than 18mph then it will detect a stationary vehicle - which I think is part of the City Emergency Braking. This operates whether you have ACC switched on or not. If the driver does not brake and a collision is imminent then the system applies them automatically.
Reactions: veeeight
This is in the manual, and is by design. You wouldn't want traffic bollards or roadworks signs in the road causing your car to stop just before them. Though as glospete says above, if it gets really close it'll automatically apply the brakes eventually with the emergency stop feature.
I'm surprised at the number of people who don't read the manual. There's a lot of information in there, some that is useful to know, some that you really should know before using certain features!
Reactions: Martinbanshee
Wow - in a way I'm glad I didn't get ACC as that's exactly what I would've done.
I can imagine a scenario where it's tracking the car in front, so when it stops I'll stop etc. I get used to that.
Then that car turns away and I'm approaching a stationary car at the next set of traffic lights...and it doesn't stop.
Yikes. I'll stick to my own ACC (my right foot).
ACC is pretty awesome in all honesty, it's not perfect (what is) but it works very well as long as you know its limitations.
Reactions: Martinbanshee and cemerson
Must work differently for you guys, but my system works fine in stop start traffic where I approach stopped cars
It does brake more abruptly than you would, but you can tweak that by adjusting the distance gap on the stalk
I'll grab a vid next time in traffic
It will stop for a stationary car ahead, if it had been tracking it previously on ACC.
It won't detect a stationary car ahead, if it hadn't already been tracking it previously
eg you drive in an empty lane, then happen upon a stationary car ahead.
If you think ACC is a tool that lets you pay less attention to the road, then you will run into trouble, and frankly probably shouldn't have a licence anyway.
Kind of like how Active Lane Assist, will disable itself if it detects that you aren't steering the wheel.
Well what if you fall asleep at the wheel, or get caught up in a 187 at the wheel, the Active Lane Assist will just say sorry about your luck and steer you right off the interstate/highway.
nope, been testing this over last few days
i set the cruise with nobody in front of me and i get the green radar icon with car below it
as i approach a stationary car at the lights/intersection the icon adds the green car above the radar and the car slows down rapidly
i've tried it up to 70 km/h and i use the default setting for distance - not willing to test it at freeway speeds
checked my only owners manua andl it reads "may be restricted upon stationary car"
What country are you in?
Have you got any other Driver Assist options?
ACC certainly gives the impression that it's designed to reduce driver input in managing speed - i.e. stopping if the car in front stops. Prior to this thread I would've assumed it would stop if it detected any stationary car - pre-tracked or not.
Pretty sure this is what I am seeing as well. I'm in the U.S.
