This has been done to death but I thought this may be a definitive a "stay away from" the yellow spring post. So, interesting, I switched out my 008 spring from green to yellow, running 23psi @ stage2 and the yellow completely destroyed my boost. On green it was ballistic, kicking in around 2000rpm. (rounded out a screw so couldn't change it back, will tackl that tomorrow) Going to try green and one shim as at freeway speed partial throttle I can hear it vent slightly. The result from the yellow spring was not what I expected, it really destroyed my boost below about 4000rpm then it seemed to come on ok but not hard. Dump and induction sound is severely more quiet with yellow. So definitely definitely if you are running the 008 with the revised piston, just green and only green if you want your stage 2 to be bat **** crazy on boost.
