It's relatively easy to do as long as you have VCDS as you need to code the car. Other than that, swap antenna amp, put in line power cable in, in line fibre cable, connect up antenna amp to dab tuner and code the car.Is there a guide available on how to do this? I would like the OEM upgrade - thanks
I'd be trying an external antenna. Try a glass-mounted one.Not sure if any one can help - I installed the 4E0910563C unit and the wiring. I've enabled the digital radio via the CAN gateway and reboot the MMI 2G.
I know see the DAB radio menu - update listing. However, I don't appear to be picking up any signal?
I used this http://www.halfords.com/technology/car-audio/dab-car-stereos/autoleads-dab-film-antenna-smb-dab-aa1
Any suggestions?
