Fuel pump kill switch
troopa
I want to install one of these on my car and I'm just wondering if this is the easiest/correct way to do it...
Do i simply cut the wire at the rear of the fusebox going to/coming from the fuel pump fuse, extend both wires and add them to a 2 prong rocker switch?
Security. Ive seen other people do it like this. It only runs on a 20amp fuse. Surely a 25 amp switch could handle it?
No i just mean if someone managed to get my keys. No alarm disklok or any other type of security will stop them if they have the keys. So i wanted to do a fuel kill switch and hide it. Wont start then.
All i want to know is if i can put a 25a switch on the fuel pump wire coming from the fuse.
If you can get the clocks to turn on, (as in you would with the key, preheat ) snap n cap or slidhammer the ignition you can get them away
on immo1, and immo2!! in fact i'd add a kill switch to any of my cars , as with an item anyone can buy from the net you can get just about any motor away!!!
I would tap into the circuit that feeds the fuel pump relay.
Its low current and would kill all the injectors, pump, etc together.
Saves running meaty wires around the car.
524
14
958
10
