Paul Waterfall
- Joined
- Dec 11, 2014
- Messages
- 33
- Reaction score
- 0
- Points
- 6
My car has a rough idle and when revved seemed to smooth out to a degree, i used VCDS Lite and came up with 17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation. Fitted new cam and crank sensors plus new cam chain and tensioner, but no different. What i did notice was setting TDC that No4 cylinder was on a compression stroke ?????
As you can see on the next picture with TDC set that No1 cylinder the valves are open, I`m I right in saying the cam is 180 degrees out. I put this back together as it came apart.
Surely this cant be right, or I`m I reading this all wrong.
