Hi,
Have a TT 2011 with a retrofit RNS-E 192 Navigation Plus and was hoping to get the aux coded using VCDS but whenever I went into module 56 or 37 and tried writing the old code, I was received with the following message:
"Error 31: Request out of range - Coding Rejected"
Our current code is 0619637 and so we have tried changing the code to 0619677 (VCDS says +4 for AUX installed) and 0619657 (many sits have said to try 5) but both pop up with the error above.
Can someone help with possible a new coding we can try?
The car's scan log is below:
Sunday,05,July,2015,11:53:05:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: License Plate:
Mileage: 58300km-36225mi Repair Order:
Chassis Type: 8J (8P0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 61 77
VIN: TRUZZZ8J3B1022852 Mileage: 58300km/36225miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CES) Labels: Redir Fail!
Part No SW: 8J0 907 115 AJ HW: 8J0 907 115 AJ
Component: 2.0l R4/4V AVS 01 0070
Revision: EIH05--- Serial number: AUX7Z0K1FNN07V
Coding: 0113000C18070060
Shop #: WSC 01236 785 00200
VCID: 74E73A5B174EF4BE80B-8021
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 B HW: 8J0 614 517 B
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0083344
VCID: 2C57E23B8FFEEC7E18B-8079
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 BA HW: 8J0 820 043 BA
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001180975
Coding: 1573892
VCID: 66C350135192162E0EF-8033
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 H HW: 8P0 907 063 H
Component: BCM PQ35 H 108 0615
Revision: 00108 AG
Coding: 46000B2FA005F1202070C9E00000094C521E58AA3000D928DC000E440045
Shop #: WSC 01236 758 00200
VCID: 3979CB6FB0AC49D693D-806C
Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00FD10
Subsystem 2 - Part No: 8J0 951 177
Component: DWA-Sensor H0 H03 0030
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
2 Faults Found:
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 69
Mileage: 58213 km
Time Indication: 0
Date: 2015.07.03
Time: 20:55:05
Freeze Frame:
Term 15 Off
Voltage: 12.70 V
OFF
OFF
Term 50 Off
OFF
OFF
01179 - Incorrect Key Programming
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Mileage: 58224 km
Time Indication: 0
Date: 2015.07.03
Time: 22:34:53
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K0054WWG
Coding: 0011636
VCID: F9F98B6FB02C09D653D-80AC
Subsystem 1 - Serial number: 6332DRB40D6D8FACH
Subsystem 2 - Serial number: 6342DRB40D690C1AZ
Subsystem 3 - Serial number: 63747RB40613525DI
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004011
VCID: 4683B0933152362EEEF-8013
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 980 P HW: 8J0 920 980 P
Component: KOMBIINSTR. VDO H01 0591
Revision: D0H01004 Serial number: 2241K004004137
Coding: 0260428
Shop #: WSC 62732 001 1048576
VCID: 3E73D87369826EEEA6F-806B
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 8P0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H43 0311
Revision: H43 Serial number: 280311F1003362
Coding: 354101
VCID: 3365F94792C0B386591-8066
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:02:42
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 83
Reset counter: 255
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:08:45
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01004 Serial number: AUX7Z0K1FNN07V
Shop #: WSC 00000 000 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8J0 035 192 B HW: 8J0 035 192 B
Component: RNS-E HIGH EU H11 0650
Revision: 03S Serial number: AUZBZ7G3802332
Coding: 0619637
Shop #: WSC 05164 444 82780
VCID: 285F1E2B9B06C05EFC3-807D
7 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 63
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:09:00
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 103
Time Indication: 15
02005 - Coding Pin
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Time Indication: 15
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J8 959 801 J HW: 8J8 959 801 J
Component: Tuer-SG H04 0101
Coding: 0000565
VCID: 4487AA9B076E043EF0B-8011
Address 44: Steering Assist
Cannot be reached
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000025336
Coding: 0236117
VCID: 2541171FEC14DD36C75-8070
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8J8 959 802 J HW: 8J8 959 802 J
Coding: 0000564
VCID: 4581B79F0C543D36E75-8010
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000009
VCID: 3C77D27B7F9E7CFE88B-8069
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0619637
7 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 63
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:09:00
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 103
Time Indication: 15
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Time Indication: 15
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 0311
Coding: F322015A
VCID: F4E7BA5B574E74BE00B-80A1
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005303246
Coding: 0001222
VCID: F4E7BA5B974E74BE00B-80A1
1 Fault Found:
02503 - Output Wire to Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:02:46
End ---------------------------------------------------------------------
VIN: License Plate:
Revision: 00H60001
Coding: 0083344
Coding: 1573892
Revision: 00108 AG
Coding: 00FD10
2 Faults Found:
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 69
Mileage: 58213 km
Time Indication: 0
Date: 2015.07.03
Time: 20:55:05
Freeze Frame:
Term 15 Off
Voltage: 12.70 V
OFF
OFF
Term 50 Off
OFF
OFF
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Mileage: 58224 km
Time Indication: 0
Date: 2015.07.03
Time: 22:34:53
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
Coding: 0011636
Coding: 0004011
1 Fault Found:
01304 - Radio
Coding: 0260428
Coding: 354101
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:02:42
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 83
Reset counter: 255
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:08:45
Coding: 0619637
7 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 63
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:09:00
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 103
Time Indication: 15
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Time Indication: 15
Coding: 0000565
Cannot be reached
Coding: 0236117
Coding: 0000564
Coding: 0000009
Coding: 0619637
7 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 63
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:09:00
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Mileage: 58120 km
Count: 2906
Clock: 15:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 103
Time Indication: 15
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Time Indication: 15
Coding: F322015A
Coding: 0001222
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Mileage: 58120 km
Time Indication: 0
Date: 2015.06.29
Time: 15:02:46
