OE fitment is studs and nuts... anything you use has to be the correct hardness as the heat will stretch and subsequently loosen anything thats too soft
Those were my thoughts tuffty. Id be using the ER14 turbo to manifold screws as it was when i originally got the car (well the running gear in the other car). Ive got a set of studs I can extract from a spare turbo. Worth a shot tomorrow i guess.
Bite the bullet man. I was using bolts and nothing I did stopped them coming loose or falling out every second week. Finally got oem studs and nuts. Never a problem since. Although I took the engine out to do the job
Well the thought of trying to insert the studs using two nuts made me a bit sick due to the lack of access. I'd say I saved time pulling the engine... Sure it's only a few bolts and pipes
