- Joined
- Jul 11, 2011
- Messages
- 1,860
- Reaction score
- 440
- Points
- 83
I
Interesting, I see what happens when I get ther, but thanks for the heads up
I think you'll be fine for stage tuning, the fact of the matter being, it's easy money for him!
I
Ahh right I get what your saying id rather take it to awesome gti or more Bhp I think because there local and heard good things about both and I'm not after ground breaking Bhp figures just want to liven the car up a bit if I can get 210 from it il be happy ..
But I only have an exhaust system which consists of 3" downpipe to 2.5" system with just a back box and then a ram air filter set up what else should I change/upgrade before the map
You should see about 210 with no mods from stage 1 map. For full stage 2 it would be recommended to get a FMIC, you'll see good benefit from it for sure... Can make a decent enough one up for about £250
Not sure about that Ram filter as well, is it oiled or dry?
Ahh because iv seen people recommend new DV and turbo intake pipe but don't want to spend on unnecessary mods really and I do want a front mount but have no clue where to start and don't want to it on show if want it hidden behind the bumper
Also from memory I think the filter was dry..
The car seems to rev more freely now both the exhaust and filter are fitted certainly sounds better aha
You're half way to going stage 2 with the mods you have. A FMIC would be a good choice, a stealth install is definitely possible; if not a little tricky.
If you're going that far then you might as well get a supersize TIP, frees up the flow on the intake side and is proven to increase power. As for recirc valves you need anymore than an OEM valve, if you want to freshen it up for a new OEM valve go for it. But an aftermarket one won't really give you any more than a shiny valve under the bonnet.
Yeah I was told I was into stage 2 with an oversized tip, ramair panel filter (dry foam, and a downpipe and decat, I have no idea what bhp I'll get but if I get 200 I'll be pretty pleasedYou're half way to going stage 2 with the mods you have. A FMIC would be a good choice, a stealth install is definitely possible; if not a little tricky.
I am going to get a fmic, but I don't know what to get first, suspension, clutch and flywheel or the intercooler, what would you suggest.The efficiency of the standard SMIC is questionable at stage1, let alone 2... Data log any stage 2 car with standard SMIC and even with ambient temps in their teens you really wont have to do much to get AITs into the 60's.
It's fine and perfectly safe as the ECU pulls timing when AITs reach 35°, but AITs that high are obviously not going to be good for power, no will pulled timing!
Right, my experience at r-tech was a good one, niki gower and the guys where really friendly, and a bloke named Ben even drove my dad and the missis to the pub because they didn't want to stay and listen to lots of noise, sorry I was mistaken it wasn't a boost pipe it was the crack breather pipe so nothing serious.Okay sound may look into iv read online that they don't actually give any notable gains but heard mixed reviews on them so not sure what to do really and how did it go at r tech?
Turbo intake pipe, ramair panel filter, 3" downpipe and decat, that's it for mods, but I did have the sai removed, n249 bypass and pcv simplify and oil catch can added, r-tech recommended this to allow the engine to breath better and so there is less pipe work to cause leaks. Oh but with the added power you will definitely need to upgrade your brakes and I would do it before the remapAhh that's good service then! I'd be happy with 220 what other mods do you have on yours ?
Yeah you won't need the fmic straight away, but after the remap you might want to consider a fmic or even a larger SMIC, either will help to keep things cooler. But honestly you won't believe the difference, it's even better when you don't know what to expect, just like me.That's sound then I may not bother with the front mount first just get my car mapped an see how it performs but yea il deffo be updating the brakes for 312mm ones
I must say I do like your A3 very clean example from the outside, unlike mine with scrapes here and there, not caused by me may I add, and I've received even more in the last couple of months since owning her, people for some reason like to open there doors on to her body work and scrape down the side while they park, so for me I look for performance rather than aesthetics, so people will look and go what a s**t heap but the thing is this s**t just burned them up, but still nice looking motor.Need to get all my niggly problems fixed before I can think about getting it mapped which I want to do but a lot of little things add up to one big job..
Going to get a quote from a body shop today when my dad takes his t4 in to be sprayed and have bits fitted.
Any way went all types a few weeks back so here's some pics
Just a random one after a drive
Dog bone mount is cheap cheap, wishbones on the other hand can be a bit but pricey, do you know what your gonna go for OE, powerflex or super pro? Super pro look really good, there is a you tube comparison, plus there about £80 cheaper, luckily for me I have a mate who's a mechanic who works at vw, he does work for me cheap, he's fitting my coilover kit and cold side dv relocation kit on MondayYea I know what you mean but need a fair few jobs doing first the car feels terrible at the moment and got nocks from what I think is a worn dog bone mount and need wishbone bushes replacing but can't do them myself or else I would aha
Driven my mates 220bhp golf an can 100% tell I need a map aha!
Even better for you then, some brotherly love there then, so what bushes you gonna use?I can do most jobs myself line fitting exhaust and coilovers all relatively easy but never done bushes and understand you need a press to get them in and out ? My step bros a mechanic of 20 years but he seems reluctant to waste his Saturdays on my car
How low is your car dude?, do you suffer from any rubbing?and did you climb a tree to take that second photo?Even better for you then, some brotherly love there then, so what bushes you gonna use?
Wow, what's the ride like that low, I'll be definitely using superproYea he's a good help! And iv heard good things about super pro and also bad reviews of power flex so not so sure really..
And I'm pretty much all the way down with no helpers in and no rubbing on the front only rubs on rear with 4 people in
Ah selfie stick, that thing was long as a tree then, mega extendable, remember when you get the remap make sure it's custom, also why a forge quick shifter I'm pretty sure you can the same cheaper just without the name written on it, try creation motorsport I think they do one for about £40 I think it does look slightly different from forges but if it does the same think for half the money it's a bonus, have a look and see what you think, the rest of the money can go towards your mapping.And also I didn't climb a tree one of the girls had a selfie stickI wasn't taking a selfie so it's okay aha going to a local place to quote for a remap and other parts tomorrow so In the near future I should be above 210hp with the mods I have need 312mm brakes next and a tt or s3 arb I believe ? Instead of buying a different car I want to improve this and eventually push for 300hp as I feel a fairly ordinary looking car pushing that power will be a laugh
Went to get my dad from dropping his t4 off for a respray an other bits and got a quote for tidying up my a3 and painting and fitting an s3 spoiler
Looking for a splitter to improve the front may have to be a leon one as can't see why else will look good
Good photo location though
Also thinking of buying the forge quick shifter which makes the throw of the gear lever shorter (had a go in my mates mk4 gti with it fitted) bit odd to get used to though
I'm also considering changing my arb but I was told by tuffty I'd need different droplinks to use it, there is a TT one on eBay at the minute, but it now price £50, yeah I know what you mean by wanting to get as much power from these cars, but I'm afraid it starts getting serious money very very soonAh selfie stick, that thing was long as a tree then, mega extendable, remember when you get the remap make sure it's custom, also why a forge quick shifter I'm pretty sure you can the same cheaper just without the name written on it, try creation motorsport I think they do one for about £40 I think it does look slightly different from forges but if it does the same think for half the money it's a bonus, have a look and see what you think, the rest of the money can go towards your mapping.
That arb is sold I just checkedI'm also considering changing my arb but I was told by tuffty I'd need different droplinks to use it, there is a TT one on eBay at the minute, but it now price £50, yeah I know what you mean by wanting to get as much power from these cars, but I'm afraid it starts getting serious money very very soon
Nice one.. Not sure but i pulled on my mates standard leon cupra r and ruined a ep3 type r so happy with it, my mate said should expect around 220 ish need to get it on rollers but would have to higher it ahaLooking good mate
What power you making after remap,
