this is what's come out of the car, golden in colour...
The only fluid I've come across before is either green or red, what can I top it up with apart from going to Audi, as I'm guessing it's the original Audi fluid?
Just get it from the dealers, its pretty cheap and you know then that you have the right stuff....if i remember correctly, I only paid about £8 for it when I needed it.
i have a few friends who also drive vag vehicles and two of them had to take their vehicles in for repair after a while after using dexron II based atf's in their reservoirs. after reading up a bit on the forums i came across this statement about 2 years ago.
Never use regular power steeringfluid in these cars! If you do, you will eat away all of the seals in the power steering system and auto leveling hydraulics(in the rear) and cause unimaginable leaks leading to replacement of most of the components in these systems. The Pentosin fluidyou should use is CHF 11S. It is green in color. If you have a leak in the system you should fix it immediately, the leak will only get worse and replacing the fluid so frequently will cost more $ than the the part would if you had just gotten it fixed.
thus i suggest and recommend only the mineral based dealer fluid.
