Mark Greenall
Hi, really need some help here. I have a a3 1.8t. I had a misfire on cylinder 3. swapped coil packs and it stayed on number 3. I realised icm (ignition control module on the airbox) was bad so I tried to repair it but when I refitted the module the car wouldn't spark at all on any cylinder so I knew I had broken the module completely. I got a used 1 today (not ideal I know but they are 200 pounds almost.) But when I fit the new one, the car still doesn't fire not even misfire just does not produce a spark to any cylinder. I have followed all wires they seem ok. I'm worried I have damaged something with my bad repair or blown a relay maybe. It could be a bad used item, but why won't it just misfire like before? Is there any other fuse or relay other than the side of steering wheel? I have checked those and all seem fine. Plugged into vcds no codes. But it's an agu.
