Sidelights fallen out!!!!
Nilz
Defo worth the wait :)
So one of my sidelights decided to stop working yesterday and as I went to pull it out, it unclipped and fell into the headlight section.
Is there a quick and easy way of getting this out??
Nilz
I had this recently when an LED sidelight bulb fell in mine.. I removed the main beam bulb and used a bit of blu-tac on the end of a long cable tie to poke through and grab the bulb...
Use a little bit of tape around the top part of the blu-tac to help secure it to the cable tie and stop it falling into the light as well... helps if the blu-tac is warmed a bit as its 'tackier'
<tuffty/>
Reactions: Nilz
Had this happen too, buy one of them magnetic pen things and it should pick it up
Reactions: Nilz
I was going to try the tape on the end of a cable tie thing, but then had a panic and thought thats going to get stuck in there as well.
I will give it a go when I get a chance :)
Ive still got one of my friends prozi drive pieces in the back of the headlight, its not going anywhere, but its not comming out either ! lol, good luck with the bulb, good idea tufty, and Tesco sell them magnetic tools, (rolson) in the big'ish stores
Reactions: Nilz
If you make the blu-tac tear drop shaped and secure it to a good lenght of the cable tie rather than blob it on the end it should hold on fine
<tuffty/>
Cheers Paul, will probably try it on the weekend....only thing is I have changed the LED and its a slightly different shade, so im concerned if i try to change them again they will ****** fall in!!!
Powerful vacume cleaner over the main beam bulb hole might work.
Reactions: Nilz
Hello stranger!!!
@Speedy Steve, i may take your dice idea for inspiration....lol!!
Reactions: Speedy Steve
25
20
804
656
Maz
