PLEASE HELP - NEW CAR VCDS ISSUES
jamin128
Poole
I am hoping someone could help me.
I have just purchased a 12 year old A4 B6 Cabriolet 2.5 TDI.
I did a scan when I got home with it, and it highlight numerous issues.
Please could someone help me understand in what order I should address the issues ?
Are any major ?
I have very little understanding of VCDS
Thank you in advance.
Mileage: 147530km/91670miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8E0 907 401 Q
Component: 2.5l V6 TDI 0200SG 0014
Coding: 02012
Shop #: WSC 00672
VCID: 3365EBC20152268656F-4B02
Subsystem 1 - Part No: 00006059
Component: 130 106JC150_1.V79916137292
WAUZZZ8H63K022862 AUZ6Z0B0455924
5 Faults Found:
01375 - Valves for Engine Mounting; Stage 1
38-10 - Output won't Switch or Short to Plus - Intermittent
00542 - Needle lift Sensor (G80)
30-10 - Open or Short to Plus - Intermittent
18058 - Powertrain Data Bus
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
18043 - Powertrain Data Bus
P1635 - 35-10 - Missing Message from A/C Controller - Intermittent
01318 - Control Module for Injection Pump (J399)
49-10 - No Communications - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04455
Shop #: WSC 00672
VCID: E5C1C59A7F06083688B-5140
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00100
Shop #: WSC 00672
VCID: 295909AAD39E6C56EC3-5140
2 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00672
VCID: 3467E8DE045C21BE4F5-4B1C
No fault code found.
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 1015
Coding: 0011104
Shop #: WSC 00672 785 00200
VCID: 3979D9EA733EDCD69C3-515E
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 01011
Shop #: WSC 00672
VCID: 3663D2D6122033AE711-4B1C
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 C
Component: KOMBI+WEGFAHRS. RB4 D16
Coding: 00401
Shop #: WSC 00006
VCID: 2C57F0BEDC6C797E175-515E
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6185
VCID: F3E5ABC291D2E68616F-5140
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 00000
VCID: EFEDA7B2ADFAC266F27-517C
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 D
Component: Komfortgerát T3B 1210
Coding: 06795
Shop #: WSC 00672
VCID: 3561D5DA0F2638B678B-4B34
Subsystem 1 - Part No: 8H2959802
Component: Tõrsteuer.FS BRM 0001
Subsystem 2 - Part No: 8H2959801
Component: Tõrsteuer.BF BRM 0001
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0001
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0001
1 Fault Found:
01134 - Alarm Horn (H12)
29-00 - Short to Ground
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 C
Component: symphony II NP2 0151
Coding: 13001
Shop #: WSC 00272
VCID: 275D0F92C58A5A26FA7-4E98
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
36-00 - Open Circuit
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H11 X023
Coding: 00005
Shop #: WSC 00065
VCID: 3561D5DA0F2638B678B-4B1C
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H11 X023
Coding: 00005
Shop #: WSC 00065
End ---------------------------------------------------------------------
As Paul says, many codes can be caused by low voltage over the cars life and many gargaes dont clear them out or check. When i say low voltage i mean the time between the key is turned (cold and battery low) and the point the alternator kicks in, and that short period is enough to throw many ECUs if the battery voltage was below par but just enough to fire the engine.
To be honest i think these codes are factory standard , most newly bought audis im coming across seem to have most these codes. PMSL.
Reactions: jamin128
Here is a fresh scan after clearing faults:
Mileage: 147550km/91683miles
Coding: 02012
Shop #: WSC 00672
1 Fault Found:
Readiness: N/A
Coding: 04455
Shop #: WSC 00672
Coding: 00100
Shop #: WSC 00672
VCID: 295909AAD39E6C56EC3-515E
Coding: 00001
Shop #: WSC 00672
VCID: 3467E8DE045C21BE4F5-4B34
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 0011104
Coding: 01011
Shop #: WSC 00672
VCID: 3663D2D6122033AE711-4B34
Coding: 00401
Shop #: WSC 00006
VCID: 2C57F0BEDC6C797E175-5140
VCID: F3E5ABC291D2E68616F-515E
Coding: 00001
Shop #: WSC 00000
VCID: EFEDA7B2ADFAC266F27-515E
Coding: 06795
Shop #: WSC 00672
1 Fault Found:
Coding: 13001
Shop #: WSC 00272
VCID: 275D0F92C58A5A26FA7-4EB4
Coding: 00005
Shop #: WSC 00065
Coding: 00005
Shop #: WSC 00065
Regarding the injector:
Could it be the wiring?
Been quoted about £450 + vat to replace injector ... gutted :-(
Any help or advice anyone can give me would be greatly appreciated.
Ben
The needle lift sensor is built into injector number 3 - rear injector on the O/S bank. They are known to go and as far as I know cannot be overhauled. You can either buy a new injector from Audi or a know good replacement from a breaker or online auction.
Replacing the injector yourself isn't hard, there's several guides in the forum. Try searching for AlexGSi who replaced his and did a write-up.
Running without the sensor replaced while you source a replacement won't do any damage, it just won't be running at 100% efficiency.
The alarm sounder fault is quite common. The backup battery in the sounder unit ages and leaks onto the PCB causing the unit to be irreparably damaged and sometimes strange noises from your boot! New units about £100 from Audi or take your chances with a used one.
Frank
Hi Frank, thank you for your reply.
Do you know if the dodgy injecter would cause it to have less power?
Ben
Wouldn't imagine it'll have a huge impact on power. As far as I can make out they are more used to 'fine tune' the timing.
I read a post a while back that mentioned that if the G80 is dud then the system falls back to another sensor (possibly in the fuel pump itself) to help determine timing of the engine. If they both go down then I would imagine it'd have a significant impact.
Frank
The car can be a bit juddery pulling away, and the clutch biting point is quite high.
Also the turbo dosen't seem to pick up fully until approx. 2500rpm.
Wish i'd never bought the car :-(
Aye had that feeling with new cars before, unfortunately with cars 10odd years old there will always be something suppose it depends how well they've been cared for by previous owners.
I occasionally get a judder when pulling away first thing in the morning, once it's warmed up its fine. Moisture can condense on the flywheel on the folders nights and this causes the judder apparently. My car has 135k and 8 previous owners but no sign of the clutch/flywheel ever having been changed.
Sometimes it's simple things with these motors, you should be getting good boost from about 1800 rpm, try checking over all the vacuum pipes in the engine bay, they'll be getting on a bit by now and a couple of quids worth of pipe may sort it. Same with intercooler pipes, any splits in these and all your boost is vented to atmosphere.
It can be a pain but when running correctly the V6 diesel is a really smooth drive.
Frank
With the third injector faulty the ecu reverts to Base settings which are inbetween limp home and normal, wont do any damage as frank says but will be bit rough.
