[8P BMN] unstable engine work, a lot of blue smoke.
tomo_git
Hello.
Today I replaced injectors in the car at 03G 130073 T, that is as it should be.
This is video with the problem :
During acceleration feel as if the car jerking /interrupt. The higher the speed the greater thejerking when accelerating.
At idle smokes blue.
Injections have good offsets each approx. 0.50-0.60.
I would add that the turbo is in perfect condition, was checked.
Logs: http://vaglog.pl/log_202428.html
Did you get a set of new ones or used ones?
This used to happen to my BKD engine, got it sorted at Bosch service, they just did something with my injectors (took them approx. 8 hours) and it stopped after that.
EDIT: Blue smoke = burning oil by the way.
I get used ones, but they are after serive action 23K1.
Do you change seals and bolts for new or only you did is recovery your injectors?
Today i leave my injectors for checking condition. New seals with new bolts maybe fixed this problem?
The smoke is blue/grey.
Yeah, they did new seals and bolts as well, I forgot to mention that, sorry!
White smoke means the car is burning coolant, blue is oil, black / grey is fuel.
Reactions: tomo_git
I have one question.
Do you know why and how new bolts are fix this problem?
Do you change ignition lath to new or leave old one?
I'm waiting for information form service about the condition od injectors.
