Air con not clearing windows...
john876
Hi,
I've tried searching for the answer but not sure if I'm using the right search terms.
My windscreen isn't clearing when it is steamed up. When I set the fans to the up position the air is blowing through the side vents. I assume the fan position motor is playing up. Is this a DIY fix? Does anyone have a guide on how to fix/replace the motor?
John
Flap motors are a possibility but another thing to bear in mind that the a/c doesn't operate in temps below 5(?) degrees so it will take it longer to demist.
