remove the panel where the sub and amp are.
get a can of expanding foam and fill everywhere you can get to. get all the little gaps and crevis's behind the apm and sub
then keep going until just before its spilling out the cabin then refit the panel and forget about any noises
I did the same thing. I removed the entire rear light (just 4 screws on the inside and I think a couple on the outside) then I could reach in and get the bulb. I guess you could try your luck with sticking a magnetic pick up tool down there
