with your pictures - the A7 daytime pictures don't match the same car as the dark picture with LEDs on - the headlights are different as are the wing mirrors. You sure that is an A7?
I'm fairly sure it is an A7, and the apparent difference in the line of the light is either 1) down to reflection in that lower piece, or 2) the difference between rendering and fabrication.
I can only see the new TT and the A7 with the grille quite as angular as it is - and badge positioning puts the TT out (for starters); the rest of the current crop do have the trapezoid shape, but it's more subtle than on those too; and certainly whatever it is has quite a wide stance [*washes mouth out with soapy water*].
A reverse image search on the one we use as a background seems to have an A7 bias in the results (I'd root through the press release images, but it's rather a big pile!).
