Hazard Lights Only Working On One Side!
mini-si
Tamworth
Hi all,
Notice today that the when I put my hazard lights on the off side don't work at all?
They work fine when indicating, all bulbs front, side and rear work as they should when indicating but not when using the hazards.
I'm guessing it's a faulty/sticking relay, if so where about is it?
And is there a way to test/ bypass it to prove what's at fault?
Thanks in advance as always guys
its your hazard switch that needs to be replaced (the hazard switch is also your indicator relay but they are controlled by 2 seperate modules inside the switch) thus if the hazard part fails the indicators still work of vice verse. replace the switch (or the hazard relay inside of it) and your problem will be resolved
The relay is built into the hazard switch in the centre console, they are about £40 from main dealers and takes about 30mins to replace, just be careful not to scratch/damage the finish of the console when doing so.
