Retrofitted an 8P (8P4 867 689) cargo net on my 8V
Schizophonic
Northampton
You can never have enough storage. Was umming and wondering if this was going to work but took a gamble and so far its worked out pritty well.
As you know on the 8P there was a cargo net that goes flat with the under tray of parcel shelf. I saw this on ebay and took the risk to purchase this.
The first problem was the orientation, as you can see from the picture below when trying to line up the shape of the cargo net it wasn't going to fit. There was a large gap and it wasn't going to fit flush.
IMG 20140730 115220
The simple solution was to rotate the bar around and with along the support side. This would allow the net to sit flush against the curves of the under tray of the parcel shelf.
IMG 20140730 115144
IMG 20140730 115134
Once I decided this would sit neatly I needed to move the elastic band to the other side but the hole in which it sit in wouldn't be big enough. So with some appliers and a bit of force I was able to make the metel housing a bit smaller.
IMG 20140730 114417
IMG 20140730 114747
So as you can see from the below, it would fit neatly and tightly in the space available.
IMG 20140730 115008
Now with a bit of alignment you can see how this was going to fit.
IMG 20140730 115202
And with the mesh fitted.
IMG 20140730 120227
With some 3x12mm screws in place and to hold the cargo net down we have our finished result.
Note, I've tried it with 3x16mm and this would go through the shelf resulting in some sharp spikes along the top side of the shelf.
IMG 20140801 112547
Any questions feel free to ask.
Reactions: Audimad, REB154, carys3 and 3 others
