so i recently took my BAM s3 8l off the road for some work. I replaced the clutch, timing belt, water pump, EGT, gaskets, silicone pipes, and a brand new genuine turbo. I finally got it put back together yesterday and took it for a spin. i oiled the turbo before installation, cranked the engine over with the fuel pump fuse pulled to get the oil moving and brought it for an easy drive. After a while i decided to give it a bit of boost and heard a pop like a boost pipe came off. I had a look tonight, i took off the red pipe of the turbo and it was fine, i took of the TIP and it seemed fine, i checked the intercooler pipes and they all looked fine too. I jacked the front of the car up and pulled the haldex fuse and boosted it but heard nothing so its only doing it under load.
These are my symptoms
When i boost it, it sounds and feels like its choking hard with no power and dumping some serious air with a VERY loud whoooooshh!! even though i have the standard dv. there is no real pull.
I unplugged the N75 this evening and it drives perfect although it feel like a 1.4. I have my suspicions that my creative motorsport TIP is maybe closing in on itself when the turbo spools but i may be wrong of course
I have scanned for codes and only one comes up, the EGT sensor one
Any thoughts?
Any thoughts?
