swarcup
Can anyone tell me if its possible to test the N75 valve, i have a hesitation on the Boost just as the pressure is starting to build just for a split second it looses it and then seems to come back but phasing in and out. Its as if it cant hold a certain boost pressure. I have changed all of the vac pipes and given it a scan on vcds but no fault codes related to the engine are stored. Can you test the N75 or is it just a change and chance that its the correct part. I have also blanked off the egr and disconnected the vac pipe and plugged it. Engine is a 2.5 tdi AKE. Looking at this diagram what else could it be apart from the N75 or the 2 pressure convertors. Any help would be much appreciated
![Vac Vac](https://www.audi-sport.net/xf/data/attachments/21/21193-6ef61ebb70c7aac51edddde32068d6d6.jpg)
