Annoying problem with rear window maybe a VCDS problem.
dandav1985
Active Member
Newcastle upon Tyne
Hello,
This is getting to be a annoying problem for me, if I hold the open bottom on the key fob down all the windows go down, but when I hold the closed only the front windows go up and leaving the rear windows down. Had a look on VCDS and can not seem to find anything, will I need to adapt? Someone has told me it may because my car has folding mirrors but I find this hard to believe.
I've changed the rear passenger window switch, still no joy also I've tried resetting them to there upper and lower limits using the window switches and still haven't got anywhere with is.
Also previous scans show no errors and the rear window coding is 00144.
i have the latest version of VCDS.
Car is a 59reg audi s3 sport back.
cheers in advance
Dan
have you set all windows in the mmi
can do it on my a4 a3 may be diffent
Hello,
Thanks for the reply, what's MMI Is that the DIS?. I've selected the conviniance window option in DIS.
Still no difference.
Cheers Dan
should do it then if its selected
That's the thing it's not! Really want to try and sort this thought the rear passenger switch was holding it out, replaced that and still not one touch up or closing with the key.
Cheers Dan
so you havent got one touch either on the button
can you feel the 2nd lil click when you pull up ?
Hello
No one touch on the rears, All the rear window switches have the two down and up clicks and I'm pretty sure the coding is correct(00144)
Cheers Dan
Yes the closure wont work for rears if the one touch isn't working, that sounds like a coding issue tbh, have you checked 62 & 72 coding?
Yes I have the coding is 00144, is this correct? I spoke to a guy on mk5golfgti (ed) and he says the coding seems correct. If someone has a a3/s3 similar to mine it would be very apprieative if some one could post up there coding for the rear windows.
This car has had loads of problems with it since I bought it so I'm trying to iron out all the bad points.....seems like everything on this car has previously been a bodge job......
Cheers for the help once again
Dan
Here's a scan from 2 days ago
Can some one tell me if my coding is correct for the rear door controllers.
Saturday,03,May,2014,19:38:40:13746
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.5.0.0 (x64)
Data version: 20140501
VIN: WAUZZZ8P7AA093062 License Plate: S3 NEW
Mileage: 72620km-45123mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 62
65 72 77
VIN: WAUZZZ8P7AA093062 Mileage: 72620km-45123miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AP HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0INFNA10J
Coding: 0103000C1C0F0160
Shop #: WSC 00772 129 00000
VCID: 0009E7695336B13BA7-8055
No fault code found.
Readiness: 0110 0100
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 013 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2601
Revision: 05351113 Serial number: 00001103120520
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 1C31B319DF9E75DB5B-8049
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 16428012092B00FD680B01EA901B00813D0000
Shop #: WSC 12345 123 12345
VCID: 7AFD9581F5EAEBEBE9-802F
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BL HW: 8P0 820 043 BL
Component: KlimavollautomatH09 0140
Revision: 000297 Serial number: 8P0820043BL
Shop #: WSC 00000 000 00000
VCID: 77FB8CB506F8F68396-8022
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AJ
Coding: 0E000A3FE827F0C0207241E00100895C457E2BAA307DD969E4 0040840040
VCID: 326D7DA16D1AD3AB61-8067
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93640931709286
Coding: 000103
VCID: 428D2D61DDBA632BF1-8017
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB00470HE
Coding: 30314238303830303037554A305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FAB145516E89E436E-801A
Crash sensor for side airbag; driver side:
Serial number: 3572DRB40000D920EAA1
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000D91CAB22
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB4000051F70159
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB4000051F6035B
Crash sensor for front airbag; driver side:
Serial number: 35547RB400006213589E
Crash sensor for front airbag; passenger side:
Serial number: 35647RB4000062135F7K
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 4685317131925F0BDD-8013
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 K HW: 8P0 920 982 K
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03004 Serial number: 224NI004000958
Coding: 0001418
VCID: 418F226D18BC7833E8-8014
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09B09063D
Coding: EDA37F07400602003103
VCID: 69DFDACD404C507310-803C
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 4
Mileage: 72621 km
Time Indication: 0
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 44812B7907AE6D1BC3-8011
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03004 Serial number: AUX7Z0INFNA10J
Shop #: WSC 00137 211 56823
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0220
Revision: 0000012S Serial number: AUZBZ7LD201789
Coding: 0200757
VCID: 34617BB9570EDD9B73-8061
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 M HW: 8P0 959 801 M
Component: Tuer-SG H04 0100
Coding: 0004788
VCID: 4587367D0C945413D4-8010
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 234 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 M HW: 8P0 959 802 M
Coding: 0004788
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: 7AFD958135EAEBEBE9-802F
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0200757
Address 62: Door, Rear Left Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 38100 001 1012557
VCID: 4383286502A06A23FA-8016
Address 65: Tire Pressure
Cannot be reached
Address 72: Door, Rear Right Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 428D2D611DBA632BF1-8017
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005143603
Coding: 0011422
VCID: 75E786BD1CF4849384-8020
End ---------------------------------------------------------------------
Cheers Dan
That's weird I states vcds version 14, just checking with RT about this as I cant find that version on cable based vcds.
NHN and dandav1985, VCDS 14.5 is the current Beta with support for the HEX-NET WiFi interface.
I would run the Autoscan on 12.12.2 - the current release of VCDS and see if there is any difference.
If there is a difference, we need to know and need to look into the Beta to see what is up with it.
Reactions: dandav1985 and NHN
144 is correct coding for one touch, also the front doors look correct for 5dr chassis, just to verify, do the drivers window switches operate the rear windows at all?
Hello,
Yes the front/rear switches work and rear switches work, but the one touch will not work on either......I'm glad the coding is correct at least that's a step in the right direction.....
Cheers Dan
Well I'd check 09 for any relative coding to the door numbers as in 3 or 5dr, any changes you may have made, it is strange.
Hi
i I have a 2007 A3, this week the electric mirrors have stopped working/folding using the drivers door switch and the rear windows won't work with the drivers door switch either. The rear windows work with their own switches, all wiring and fuses are ok, could a new module be needed? Current one is 8P0 959 801G and I can't find a replacement anywhere!
paul
Here's a new scan done with the 12.12 VCDS still no error codes for the rear door and all the bytes are tick as they should be.......Still confused.
Sunday,25,May,2014,19:34:06:13746
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Dealer/Shop Name: Daniel Miller
Workshop Code: 123 12345 012345
VIN: WAUZZZ.............. License Plate: 25/05/2014
Mileage: 73260km-45521mi Repair Order:
65 72 77
VIN: WAUZZZ8P7AA093062 Mileage: 73260km/45521miles
01-Engine -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
VCID: 80096769D336311E1B7-80D5
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 72979 km
Time Indication: 0
Date: 2014.05.15
Time: 13:35:28
Freeze Frame:
RPM: 814 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 43.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.716 V
Readiness: 0000 0000
Coding: 0000020
VCID: 1C31B319DF9E75FE67F-8049
Revision: 00H30001
VCID: 7AFD9581F5EAEBCED53-802F
VCID: 77FB8CB506F8F6A6AAD-8022
Revision: 00105 AJ
Coding: 0E000A3FE827F0C0207241E00100895C457E2BAA307DD969E40040840040
VCID: 326D7DA16D1AD38E5D3-8067
Coding: 00DD13
Coding: 024C2D
Coding: 000103
VCID: 428D2D61DDBA630ECD3-8017
VCID: 4FAB145516E89E6652D-801A
Coding: 0014142
VCID: 4685317131925F2EE1B-8013
Coding: 0001418
VCID: 418F226D18BC7816D49-8014
VCID: 69DFDACD404C50562C9-803C
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 72621 km
Time Indication: 0
Coding: 0000005
VCID: 44812B7907AE6D3EFFF-8011
Coding: 0200757
VCID: 34617BB9570EDDBE4FF-8061
Coding: 0004788
VCID: 4587367D0C945436E81-8010
Revision: 00H20000
Coding: 0004788
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Coding: 0000013
VCID: FAFD1581B5EA6BCE553-80AF
Coding: 0200757
Coding: 0000144
VCID: 4383286502A06A06C65-8016
Coding: 0000144
VCID: 428D2D611DBA630ECD3-8017
Coding: 0011422
VCID: 75E786BD1CF484B6B81-8020
Any more pointers.................................
Cheers Dan
I cant suggest much else, without seeing the car mate.
Where abouts are you Nigel? Maybe you'll be up my way in the near Future? Would mind this sorted........as it is pretty annoying lol......
Cheers for your help.
Dan
I work all over mate, so would come out to look at the issue.
