They'e just clipped in. You will probably brake the grills taking them out if you don't remove cards as they're in tight. But worth a try as the rear cards are a mission to remove/refit
Cheers guys. Im wanting to upgrade the system and also wondered if its possibe to tap the rear speakers to run some subtle 6x9's ???
(Think my rear ones are powered by the tiny amp in the rear stock sub box..??? "Non bose")
Well I wanted to just "pop in" some 6x9's haha...
It's a stock a3 tdi sport with a stock head unit and rear sub.
Just thought of tapping in to the rear speakers to run some 6x9's but didn't know if it would cut the tiny amp out as I think the rear speakers are run from it...?
You would have to customise for that! You'll need adapter plates if you want to fit aftermarket standard size! You'll also need a wiring adapter on back of head unit
Sorry, mis led you there,
I meant I want to fit some 6x9's in the rear parcel shelf and tap in to the wiring that powers the rear quarter panel speakers.
(Not replace the rear speakers with 6x9's)
Sorry...
