Audi a3 8p rear led / coding!!!
Audi quattro
Just got it back after having the later led rears fitted to my car. My indicators flash red, I have a yellow light on permanently and the neon side light isn't on, they followed instructions but it does say will need coding after fitting
Oh and no reverse, all bulbs are there they said
The outer rings are not coming on, on sidelights.
Btye 9 to Dec = 0 (mine says 00)
Byte 10 to Dec = 0 (mine says 00)
Byte 12 to Dec = 32
Byte 19 Bit 2 Cold Diagnosis rear active (mine says be disabled)
I am not sure what the 00 would do or the cold diagnostics rear active.
Those are the correct codings. Those are the exact ones I've used and shared here on the forum. They work fine with my car.
See if you can change "00" to "0" and check the box for Cold Diagnosis.
The coding should prevent error message and switch off the yellow brake lights, leaving only the led ring on.
The outer clusters are plug & play, only the ones on the boot lid have an extra wire that has to be connected to the number plate lights.
Either the coding is wrong or the wiring is different.
