Hi, does anyone know if this is the vacuum pump hose connector and should be popping in and out of the Vacuum pump housing loosely whilst the engine is running?
It stopped today for some reason but if you push the hose slightish you can a brief hiss, someone else had similar issue but was never followed up/closed, see their video below.
<span style="background-color: rgb(250, 250, 250);"><font color="#333333">
Also when stationary with the car idling, if I pump the brake pedal a few times the idle RPM goes up to around 1500RPM and stays there for a minute or so.
Could this be the culprit to my P0171 Bank 1 too lean fault code that wont go away?
Rob.
Rob.
