Glass cleaning ???
Anthony566
North East
Hi I have a new A4 that I have had for almost 3 months and I have noticed that I have a very faint fog effect on the inside of my windscreen and when it mist's up you can still see where the delivery paper work has been stuck to the glass, I have tried cleaning the glass but this has not worked so my question is ...
What can I use to clean my glass with that will remove this film ??
non scratch sponge from tesco would do and a microfibre towel
Ronsonol lighter fluid(the stuff for zippo lighters) is used for removing sticky stuff (sticker and sellotape marks)and nail varnish remover is also pretty good at it to however don't now if you should use it on windscreens, i have used them on double glazed windows just a small squirt on to a soft cloth and wipe then used a damp cloth to remove residue, if you do use them make sure your in a well ventilated area as you will be high as a kite before you know it lol
(It does state on the tin that the fuel can be used this way, to find out if your lighter fuel does allow you to use it in this way read the tin, if it doesn't state it can be used this way dont use it)
