At the weekend I fitting my front coilovers and now I have a knocking sound .. Could it be I haven't lined the hole in the top mount with the hole in the rubber stop ?? Or could it be something else ?
There fx ones and cost 365 so there not cheap ones
well at the top of your spring you have a rubber mount the holds your spring in place on the rubber mount you have a little slot it the side of it witch should line up with hole in the metal plateGlad ur noise is sorted.
Bit of a dumb Q but could u explain more about holes n spring?
Im not with it?
