Tyre Size Option
TinTin
225 is fine on 7.5" wide rim
slightly lower profile (45% of 225 vs 45% of 235) but nothing you will notice!
225 shouldnt affect the speedo its the 45 profile that will affect it if you swapped to a higher/lower profile on the same size wheel, if you swapped from a 45/17 to a 45/18 you would affect the rolling radius which is why you would fit a 40/18 or 35/18 tyre to compensate the rolling radius !!
i run 225/45/17 on 8" wide rims !
But the "45" is a percentage of the width. So if your tyres are 225 the profile will be slightly less than 235 width tyres.
I think 225/45/17 is actually the standard tyre size on the b5 though isn't it? I'm sure I remember having this argument with scottb5 (a nice argument) because my b6 uses 235 as standard, but he said it was 225.
Thanks guys.
Tyres on the way...just need to get them fitted early next week.
As above. I run a 225/40/18 on a 9.5j and even though that is a little stretched its still as safe. Fulken even state that in their fitting guidelines :D
891
964
966
