ticketyboo90
Hi All, I own a 52 plate 1.6 8v audi a3 with 76k on the clock. I know it's not the best of engines lol. Anyway, every so often the low oil level shows and beeps on the dash followed by a eml. When I get out, let the car sit for 15min, check dipstick and it's fine! I get back in and the oil light goes off! After a few journeys the eml goes out and yet a few more times driving about the exact same thing happens! I know i have the wrong oil in (semi synthetic). Which I will be changing the filter and oil change for castrol edge 5w30 fully synthetic. I am also wondering wether it's worth changing the oil pump, and both oil sensors. I have some sealent which I will be using to put the sump back on as I am planning to give that a good long clean. I'm pretty confident I can take and clean out the sump but not to sure about the oil pump. (I just don't want to do a full oil change and cleaning the sump out for it all to come back off to get at the oil pump. The previous owner never had it serviced for years and so far It's already had a new oil mount that the filter screws to as that was damaged. I've also changed thermostat housing, stater motor, a mechanic done the cam-belt and water pump changed. I also did the breather pipe as that was split from where it attaches the rocker cover. I've changed air and pollen filter. I don't thinks it's ever been serviced! So yeah anyway it needs an oil makeover! I may just leave pump in but clear sump. Is there anything anyone can think of why my eml is coming on? I think it's the oil level sensor but I just don't know! I would of scrapped this car if I hadn't spend so much money repairing it, underneath it's pretty much a new car!
