I have been having issues with my engine cooling system recently. Identified faulty coolant temp sensor and coolant level sensor with OBD. Removed and replaced both of these parts and refilled system.
I am now getting the following fault codes displayed: Engine Coolant Level Sensor (P255600) / Engine Coolant Temperature Sensor (P011600) / Engine Coolant Bypass Valve Control (P268100).
I have had the bypass valve/connections checked and all seems to be in good working order. When I start the car up from cold and the engine temp reaches 50°C the exterior cooling fans come on full blast and bring the engine temp straight back down. I'm thinking it could be a possible thermostat issue. Thought I'd check to see if anyone else has experienced this.
Any advice is greatly appreciated, Cheers
