Audi A3 8L 130 ASZ - Again.
JimmyJ
Hi guys.So i've just bought an OEM airbox, MAF meter/sensor and the pipe that connects the air box to the turbo.(the previous owner had a barry boy HKS mushroom filter that wasn't even fitted correctly - which I suspect was throwing my car into limp with ESP light coming on)the parts have come off a 2002 1.9 tdi but i'm not sure what the engine code or BHP was. (mine is also a 2002)Does it make a difference to car - so if it was say a 100 or 115 bhp tdi - are there any compatibility issues with my ASZ 130?Someone who's had a look says it's the wrong pipe?Any guidance guys?Jimmy
Hi i have a a3 tdi 130 2002 sport send me a picture and i will compare with my one.
Here is the pipe i've got today.
here is the mushroom i've started with and now removed.
The pipe and airbox you have there are from a TDI PD 100 model and will not fit your car.
The 100 & 115 Bhp pipes, MAF and airbox lid have a smaller diameter.
You will need to source an airbox lid from an S3, TDI 130 or 150 (Golf, A3, Leon) or Golf V6 4motion.
You would be better off buying a new MAF, the TDI relies 100% on the MAF for it fuelling, I would not trust a used one.
The Accordion pipe will also need to come from a TDI 130 or 150 (Golf, A3, Leon).
Will pipes/airbox/maf from a 130bhp passat work?
Can anybody help me with part numbers?
No Passat has totally different setup.
You can tell the two airbox lid types on the MK4 platform apart as the one for the larger MAF has a recessed bit where the MAF joins.
Its the one on the left:
A2
Cheers mate.
Would I just need the plastic pipe that connects from the MAF to the aluminum pipe or do I need a whole new accordion pipe too?
Here it goes sorry for the late reply,I was very busy at work.
