Getting a new turbo and map soon, should be pushing around 220bhp and 360ft/lbs. After looking into clutch kits I'd prefer DMF because it seems single mass can cause other problems, plus chatter would bug me. Only issue is I'm not sure how DMF's hold out as Sachs is rated 350ft/lbs(+?), can anyone confirm whether this will be fine or if there's better alternatives, SMF's may be ok if you can recommend a good one. Thinking of going for a side mount intercooler to keep a stock look but not sure this is ideal either. Thinking for brakes it'll be 312mm front and 282mm rear. Just wanted some input and to see if anyone could point out other things necessary to support the power.
