Biiiiigggg Favour from anyone who knows what the logs should look like for TFSI
OVRA3
Norwich
Hi All,
If anyone could take a look at this log and tell me if they see anything obvious amiss please? Its the wastegate cycle that I cant figure out...
Group 114 - Field 0TIMEGroup 114 - Field 2TIMEGroup 114 - Field 3TIMEGroup 115 - Field 0TIMEGroup 115 - Field 2TIMEGroup 115 - Field 3
Engine Load - (specified)STAMPEngine Load - (actual Value)STAMPWastegate (N75) - Duty CycleSTAMPEngine SpeedSTAMPBoost Pressure - (specified)STAMPBoost Pressure - (actual)
% % % /min mbar mbar
124.80.1622.60.1600.218000.213800.211010
124.80.420.30.400.458000.453900.451010
124.80.6620.30.6600.728000.723800.721010
124.80.921.10.900.968000.963800.961010
124.81.1721.11.1701.238001.233901.231010
124.81.4121.81.4101.478801.476501.471000
124.81.6834.61.6801.7310001.735001.731000
130.81.9332.31.9301.9810801.985201.981010
131.62.1933.12.1902.2410802.245702.241010
131.62.4334.62.4302.4910802.496202.491010
127.12.7137.62.7102.769602.769602.761020
124.82.9548.92.952.43.0110003.0110003.011020
135.33.2255.63.2203.2712003.279203.271030
141.43.4654.13.4603.5212403.529603.521050
137.63.756.43.703.7713603.778803.771060
153.43.9651.93.9604.0115204.0110004.011080
172.94.1757.94.1748.24.2517604.2513704.251080
1854.4251.94.4204.518004.52804.51120
181.24.66184.6604.7417204.742804.741090
166.24.92154.9204.9815204.982804.981060
138.35.16185.1605.2111605.218105.211040
149.65.4247.45.4238.45.5113605.5113505.511030
148.95.6761.75.6794.95.7313605.7316505.731050
153.45.9476.75.9494.95.9914805.9917305.991090
163.96.1981.26.1994.96.2416406.2415906.241140
177.46.4472.96.4406.517206.52606.51170
177.46.6723.36.6706.7316806.732706.731140
167.76.9314.36.9306.9815206.982806.981080
148.17.17157.1707.2213207.222707.221050
140.67.4125.67.4194.97.4913607.4920307.491020
139.87.6872.27.6894.97.7313607.7320307.731050
147.47.9173.77.9194.97.9614007.9620607.961090
150.48.1676.78.1694.98.2114408.2121008.211130
153.48.3978.28.3994.98.4515208.4521408.451160
162.48.6685.78.6694.98.7116008.7122508.711200
169.28.990.28.994.98.9516808.9523908.951250
178.29.1796.29.1794.99.2117609.2123909.211320
182.79.41100.89.4194.99.4618409.4624209.461380
185.79.67105.39.6794.99.7219609.7224409.721450
183.59.891099.8994.99.9720409.9724609.971500
182.710.1911510.1994.910.24216010.24247010.241570
183.510.41121.110.4194.910.48228010.48247010.481650
183.510.67128.610.6794.910.74240010.74248010.741760
183.510.9136.810.994.910.98248010.98249010.981860
183.511.17145.111.1794.911.25264011.25249011.251980
183.511.41151.111.4191.411.46276011.46249011.462050
184.211.65154.911.6581.611.73288011.73250011.732080
18511.91158.611.9181.611.97304011.97249011.972080
185.712.15159.412.1582.712.21316012.21248012.212050
186.512.41158.612.4182.712.46332012.46248012.462020
187.212.64157.112.648012.7344012.7247012.72030
188.712.91157.912.918012.97360012.97244012.972050
19113.16160.213.1678.413.22376013.22241013.222060
191.713.43158.613.4381.613.49388013.49238013.492040
191.713.67160.213.678013.73404013.73235013.732050
191.713.94163.213.9481.6144160142330142060
191.714.19164.714.1981.614.24432014.24231014.242040
191.714.45162.414.4585.514.51448014.51229014.511970
191.714.69160.214.6983.114.74460014.74228014.741930
191.714.94158.614.9483.114.99472014.99227014.991920
191.715.18156.415.1885.115.23484015.23226015.231900
191.715.44154.115.4482.415.49496015.49225015.491880
191.715.68153.415.6885.115.73508015.73223015.731860
191.715.95150.415.9589.4165240162210161830
191.716.19149.616.198916.25536016.25219016.251830
191.716.45148.116.4590.216.52544016.52218016.521830
191.716.71148.116.7192.216.76556016.76216016.761810
191.716.96146.616.9692.917.03568017.03214017.031780
191.717.23144.417.2392.917.28580017.28213017.281750
191.717.46142.117.4694.917.53592017.53211017.531740
191.717.74139.817.7494.917.78600017.78210017.781720
191.717.95138.317.9594.918.04608018.04209018.041690
191.718.2136.118.294.918.27620018.27209018.271660
191.718.45133.818.4594.918.52628018.52208018.521660
191.718.71133.118.7194.918.78636018.78207018.781640
191.718.94130.818.9494.919.01644019.01207019.011620
191.719.2130.119.294.919.26656019.26206019.261610
191.719.45127.819.4594.919.51664019.51206019.511610
191.719.73127.819.7394.919.8672019.847019.81540
191.719.9615.819.96020.03616020.0332020.031320
191.720.2317.320.23020.29556020.2932020.291160
191.720.471820.47020.53508020.5333020.531110
191.720.7316.520.73020.79460020.7932020.791090
191.720.9817.320.98021.04416021.0432021.041080
191.721.2417.321.24021.3376021.330021.31070
191.721.4917.321.49021.55336021.5529021.551060
191.721.7616.521.76021.82300021.8228021.821050
191.722.0116.522.01022.07264022.0728022.071060
191.722.2717.322.27022.33224022.3327022.331060
188.722.5217.322.52022.57192022.5727022.571050
183.522.781822.78022.83180022.8326022.831050
183.523.0215.823.02023.07184023.0726023.071040
186.523.2714.323.27023.33200023.3327023.331040
188.723.514.323.5023.56212023.5627023.561040
189.523.7414.323.74023.82236023.8227023.821040
190.22413.524024.06268024.0628024.061040
191.724.2414.324.24024.29300024.2928024.291050
191.724.5114.324.51024.56340024.5629024.561050
Requesting 1.4/1.5bar at 2000rpm really in a k03 turbo!? Id get original map put back on see how it goes. Also 95% duty cycle does seems very high. From top of my head should be around 75%
The log looks confusing ,but only because you're not doing a linear acceleration in 3rd gear from about 1200 rpm?
The N75 in my K04 doesn't go to zero when in acceleration, only in between gear changes (or throttle off).
594
720
883
Boydie
B
