  2. Dismiss Notice
2.0 tfsi top speed?
NC10 Jul 30, 2020
  1. NC10
    NC10 Registered User
    53
    Hi all,
    Anyone else managed a top speed run in theirs?
    I have the convertible so it is a bit heavier, but once it's at 130 it really struggles. Slowly creeps to 135 and that's about it. Obviously on a test track.
    One time I was in sport so thought it may be that as there are only 6 gears, but it's the same in normal with the 7 gears. It's also had 2 different engines, both the same.
    It's currently running 260+ bhp as well which I thought would have helped vs the stock top speed numbers.
  2. Avatar
    snack-media
    Advertisement
  3. Firas Khalife
    Firas Khalife Firoguzzi
    13
    the standard coupe can manage 245 Kph if it's healthy .
    Mine has a stage 1 tune , 270 hp , can easily reach 240 Kph
    with more to spare . maybe 260 Kph on a long run .
    NC10 likes this.
  4. NC10
    53
    So yours easily reaches 150mph, thats 20mph more than mine with roughly the same power (for arguments sake)
    I have around 200kg on the coupe so 10mph per 100kg gone :bye:
  5. Firas Khalife
    13
    with 260hp + you should hit 150 no problem . I think standard cars can reach 150 .
  6. NC10
    53
    Apparently not :frowning:
  7. Firas Khalife
    13
    If you're low on top speed , check your fuel filter .
  8. NC10
    53
    Cheers, I'll give it a try, see what happens.
  9. Sidrick
    Sidrick Registered User
    525
    343
    How does one check their fuel filter?
  10. Firas Khalife
    13
    ask your garage . It's probably in the fuel pump . If fuel filter is clogged , you might get hesitation
    at the top end .
    christoph likes this.
  11. Sidrick
    525
    343
    So your advice was to take it to the garage, but give them instructions rather than ask them to diagnose?
  12. Avatar
    snack-media
    Advertisement
  13. Firas Khalife
    13
    From personal experience , if fuel filter is clogged , you'll have hesitation around top speed/RPM .
    Of course your garage can diagnose with the proper scanner , tools . Goes without saying .
